As brood discussed above . I had test this code, it is working fine. only thing is if any one in the following variable is equal to zero. the output is goes to maximum width.
red_duty = __;
green_duty = __;
blue_duty = __;
I need if these variables are equal to zero, the output will go to zero. How can i make it to Zero , pls give the note.
Posted: Thu Jun 02, 2011 2:35 pm
I modified his code a little bit and it works better now. Here is the revised program:
