albe01
Problem with Glcd library modified |
Posted: Sun May 15, 2011 12:10 pm |
Hello to everyone... i have a problem with this library 192x64:
normally works, but if i define FAST_GLCD theres same errors and not compile it.
---------------------- this is the problem--------
void glcd_fillScreen(int1 color)
#ifdef FAST_GLCD
unsigned int8 data;
unsigned int8 *p1, *p2, *p3;
unsigned int16 i;
p1 = displayData.left;
p2 = displayData.right;
p3 = displayData.mid;
data = 0xFF * color;
for(i=0; i<512; ++i)
*p1++ = data;
*p2++ = data;
*p3++ = data;
#else
Errors of the compiler:
p1 improper use of a function identifier
p2.p3 undefined identifier
ecc ecc...
Everything is apparently normal, but if FAST_GLCD is defined not compile...
I use a pic18f4525, and include graphics.c to use this glcd
regards
#ifndef GLCD_CSA
#define GLCD_CSA PIN_D4
#endif
#ifndef GLCD_CSB
#define GLCD_CSB PIN_D3
#endif
#ifndef GLCD_DI
#define GLCD_DI PIN_D5 // Data or Instruction input
#endif
#ifndef GLCD_RW
#define GLCD_RW PIN_D6 // Read/Write
#endif
#ifndef GLCD_E
#define GLCD_E PIN_D7 // Enable
#endif
#ifndef GLCD_RST
#define GLCD_RST PIN_D2 // Reset
#endif
#define GLCD_LEFT 0
#define GLCD_MID 1
#define GLCD_RIGHT 2
#ifndef ON
#define ON 1
#endif
#ifndef OFF
#define OFF 0
#endif
// Function Prototypes
void glcd_init(int1 mode);
void glcd_pixel(unsigned int8 x, unsigned int8 y, int1 color);
void glcd_fillScreen(int1 color);
void glcd_writeByte(int side, BYTE data);
BYTE glcd_readByte(int side);
void glcd_update();
#ifdef FAST_GLCD
struct
unsigned int8 left[512];
unsigned int8 right[512];
unsigned int8 mid[512];
} displayData;
#endif
// Purpose: Initialize the LCD.
// Call before using any other LCD function.
// Inputs: OFF - Turns the LCD off
// ON - Turns the LCD on
// Initialze some pins
output_high(GLCD_RST);
output_low(GLCD_E);
//output_low(GLCD_CS1);
//output_low(GLCD_CS2);
//output_low(GLCD_CS3);
output_high(GLCD_CSA);
output_high(GLCD_CSB);
output_low(GLCD_DI); // Set for instruction
glcd_writeByte(GLCD_LEFT, 0xC0); // Specify first RAM line at the top
glcd_writeByte(GLCD_RIGHT, 0xC0); // of the screen
glcd_writeByte(GLCD_MID, 0xC0);
glcd_writeByte(GLCD_LEFT, 0x40); // Set the column address to 0
glcd_writeByte(GLCD_RIGHT, 0x40);
glcd_writeByte(GLCD_MID, 0x40);
glcd_writeByte(GLCD_LEFT, 0xB8); // Set the page address to 0
glcd_writeByte(GLCD_RIGHT, 0xB8);
glcd_writeByte(GLCD_MID, 0xB8);
if(mode == ON)
glcd_writeByte(GLCD_LEFT, 0x3F); // Turn the display on
glcd_writeByte(GLCD_MID, 0x3F);
glcd_writeByte(GLCD_RIGHT, 0x3F);
glcd_writeByte(GLCD_LEFT, 0x3E); // Turn the display off
glcd_writeByte(GLCD_MID, 0x3E);
glcd_writeByte(GLCD_RIGHT, 0x3E);
glcd_fillScreen(OFF); // Clear the display
#ifdef FAST_GLCD
glcd_update();
#endif
// Purpose: Update the LCD with data from the display arrays
#ifdef FAST_GLCD
void glcd_update()
unsigned int8 i, j;
// Loop through the vertical pages
for(i = 0; i < 8; ++i)
glcd_writeByte(GLCD_LEFT, 0x40); // Set horizontal address to 0
glcd_writeByte(GLCD_LEFT, i | 0xB8); // Set page address
glcd_writeByte(GLCD_RIGHT, i | 0xB8);
glcd_writeByte(GLCD_MID, i | 0xB8);
output_high(GLCD_DI); // Set for data
// Loop through the horizontal sections
for(j = 0; j < 64; ++j)
glcd_writeByte(GLCD_LEFT, *p1++); // Turn pixels on or off
glcd_writeByte(GLCD_RIGHT, *p2++); // Turn pixels on or off
glcd_writeByte(GLCD_MID, *p3++); // Turn pixels on or off
#endif
// Purpose: Turn a pixel on a graphic LCD on or off
// Inputs: 1) x - the x coordinate of the pixel
// 2) y - the y coordinate of the pixel
// 3) color - ON or OFF
#ifdef FAST_GLCD
unsigned int8* p;
unsigned int16 temp;
temp = y/8;
temp *= 64;
temp += x;
if((x > 63)&&(x<128))
p = displayData.mid + temp - 64;
else if(x>127)
p = displayData.right + temp-128;
p = displayData.left+temp;
if(color)
bit_set(*p, y%8);
bit_clear(*p, y%8);
#else
BYTE data;
int side = GLCD_LEFT; // Stores which chip to use on the LCD
if((x > 63)&&(x < 128)) // Check for first or second display area if((x > 63)&&(x < 128))
x -= 64;
side = GLCD_MID;
else if (x >127)
x -=128;
side=GLCD_RIGHT;
side=GLCD_LEFT;
bit_clear(x,7); // Clear the MSB. Part of an instruction code
bit_set(x,6); // Set bit 6. Also part of an instruction code
glcd_writeByte(side, x); // Set the horizontal address
glcd_writeByte(side, (y/8 & 0xBF) | 0xB8); // Set the vertical page address
glcd_readByte(side); // Need two reads to get data
data = glcd_readByte(side); // at new address
if(color == ON)
bit_set(data, y%8); // Turn the pixel on
else // or
bit_clear(data, y%8); // turn the pixel off
glcd_writeByte(side, data); // Write the pixel data
#endif
// Purpose: Fill the LCD screen with the passed in color
// Inputs: ON - turn all the pixels on
// OFF - turn all the pixels off
#ifdef FAST_GLCD
unsigned int8 data;
unsigned int16 i;
*p1++ = data;
*p2++ = data;
*p3++ = data;
#else
unsigned int8 i, j;
glcd_writeByte(GLCD_LEFT, 0b01000000); // Set horizontal address to 0
glcd_writeByte(GLCD_RIGHT, 0b01000000);
glcd_writeByte(GLCD_MID, 0b01000000);
glcd_writeByte(GLCD_LEFT, i | 0b10111000);// Set page address
glcd_writeByte(GLCD_RIGHT, i | 0b10111000);
glcd_writeByte(GLCD_MID, i | 0b10111000);
glcd_writeByte(GLCD_LEFT, 0xFF*color); // Turn pixels on or off
glcd_writeByte(GLCD_RIGHT, 0xFF*color); // Turn pixels on or off
glcd_writeByte(GLCD_MID, 0xFF*color); // Turn pixels on or off
#endif
// Purpose: Write a byte of data to the specified chip
// Inputs: 1) chipSelect - which chip to write the data to
// 2) data - the byte of data to write
void glcd_writeByte(int8 side, BYTE data)
set_tris_b(0x00); //set_tris_d(0x00);
output_low(GLCD_RW); // Set for writing
switch(side)
case GLCD_LEFT:
output_low(GLCD_CSA); //
output_low(GLCD_CSB);
case GLCD_MID:
case GLCD_RIGHT:
//default: // Deselected
//output_high(GLCD_CSA);
//output_high(GLCD_CSB);
delay_us(1);
output_b(data); // Put the data on the port
delay_us(1);
output_high(GLCD_E); // Pulse the enable pin
delay_us(1);
output_low(GLCD_E);
output_high(GLCD_CSA); // Reset the chip select lines
// Purpose: Reads a byte of data from the specified chip
// Ouputs: A byte of data read from the chip
BYTE glcd_readByte(int8 side)
BYTE data; // Stores the data read from the LCD
set_tris_b(0xFF); // Set port d to input
output_high(GLCD_RW); // Set for reading
switch(side)
case GLCD_LEFT:
case GLCD_MID:
case GLCD_RIGHT:
delay_us(1);
delay_us(1);
data = input_b(); // Get the data from the display's output register
output_low(GLCD_E);
return data; // Return the read data
#endif
Posted: Sun May 15, 2011 12:29 pm |
Post your compiler version. |
albe01
Posted: Sun May 15, 2011 12:59 pm |
PCM programmer wrote: | Post your compiler version. |
4.114 |
Posted: Sun May 15, 2011 1:30 pm |
There is no main() in your post.
Post something that I can compile and test.
It's got to have an #include for the PIC, #fuses, #use delay, #include
files, main(), etc. |
albe01
Posted: Sun May 15, 2011 1:57 pm |
main code:
#include <18F4525.h>
#define FAST_GLCD // Try commenting this out to see the differences
#include <KS0108_192X64.c>
#include <graphics.c>
#include <math.h>
void displayVoltage(int adc) {
char voltage[9];
sprintf(voltage, "%f", (float)adc * .01960784); // Converts adc to text
voltage[4] = '\0'; // Visualizza 2,3 o un decimale
glcd_rect(35, 18, 60, 25, YES, OFF); // Clear the old voltage
glcd_text57(35, 18, voltage, 1, ON); // ( 1 è la dimensione )scrive la tensione
void main() {
int1 warn = FALSE;
int8 adc = 0, adc_old = 0;
char voltText[] = " Volts", warning[] = "Batteria scarica!";// scritte glcd
//float theta = 0;
setup_adc_ports(AN0_ANALOG);
set_adc_channel(0);
glcd_init(ON); // Must initialize the LCD
glcd_rect(1, 5, 126, 15, NO, ON); // Outline the bar
glcd_text57(60, 18, voltText, 1, ON); // Display "Volts"
//glcd_circle(30, 47, 10, NO, ON); // Disegna il cerchio
for(;;) {
adc = read_adc(); // Read a value from the ADC
displayVoltage(adc); // Display the reading
adc = (adc > 249) ? 249 : adc; // Keep the value 249 or less
if(adc != adc_old) {
glcd_rect(adc/2+1, 6, adc_old/2+1, 14, YES, OFF); // Pulisce la vecchia barra
glcd_rect(1, 6, adc/2+1, 14, YES, ON); // Disegna barra aggiornata
adc_old = adc; // Set old value to new
if(adc < 150 && !warn) { // Controlla se superiore a X volts
//glcd_rect(45, 38, 124, 55, YES, ON); // con il primo valore allunga verso < Draw a filled black rectangle
glcd_text57(15, 40, warning, 1, ON); // posizione "Batt.scarica" su LCD "1" prima di ON è la dimensione
glcd_rect(2, 58, 10, 62, NO, ON); // crea simbolo batteria vuoto
glcd_rect(11, 59, 11, 61, NO, ON); // disegna testa batteria
warn = TRUE; }
else if(adc >=160 && warn) {
glcd_rect(12, 37, 125, 55, YES, OFF); // Pulisce area schermo "low batt"
glcd_rect(2, 58, 11, 62, YES, OFF);
warn = FALSE; }
// Le seguenti 3 linee fanno girare la lancetta nel cerchio
//glcd_line(30, 47, 30+(int)(8*sin(theta)+.5), 47-(int)(8*cos(theta)+.5), OFF);
//theta = (theta > 5.9) ? 0 : (theta += .3);
//glcd_line(30, 47, 30+(int)(8*sin(theta)+.5), 47-(int)(8*cos(theta)+.5), ON);
#ifdef FAST_GLCD
glcd_update();
#else
delay_ms(100); // Reduces flicker by allowing pixels to be on
// much longer than off
#endif
Posted: Sun May 15, 2011 2:15 pm |
Problem: Missing closing brace in the previous function:
Quote: | void glcd_pixel(unsigned int8 x, unsigned int8 y, int1 color)
#ifdef FAST_GLCD
unsigned int8* p;
temp = y/8;
temp *= 64;
temp += x;
else if(x>127)
if(color)
bit_set(*p, y%8);
bit_clear(*p, y%8);
albe01
Posted: Sun May 15, 2011 2:28 pm |
Thanks, I had not found the error
regards |
