I have a gear motor.. rpm: 50
What parameter i should put in setup_timer_2()
For example setup_timer_2(T2_DIV_BY_4, 255, 1);
How to make the calculation?
Kindly please help me..
Posted: Fri Mar 25, 2011 1:44 pm
1. What interrupt rate do you want from Timer2 ? 50 rpm is 3000 Hz.
Do you want a 3 KHz interrupt rate ?
2. Or do you even want interrupts ? Do you actually want to run PWM ?
3. Also, what is the oscillator frequency of your PIC ?
To get help on this forum, you need to post information about your
project.
In case your question is about PWM, here are the links to previous threads:
