about setup_timer_2.. please help
huiching
PostPosted: Fri Mar 25, 2011 7:03 am     Reply with quote
I have a gear motor.. rpm: 50
What parameter i should put in setup_timer_2()
For example setup_timer_2(T2_DIV_BY_4, 255, 1);
How to make the calculation?
Kindly please help me..
PostPosted: Fri Mar 25, 2011 1:44 pm     Reply with quote
1. What interrupt rate do you want from Timer2 ? 50 rpm is 3000 Hz.
Do you want a 3 KHz interrupt rate ?
2. Or do you even want interrupts ? Do you actually want to run PWM ?
3. Also, what is the oscillator frequency of your PIC ?
To get help on this forum, you need to post information about your
project.
In case your question is about PWM, here are the links to previous threads:
PWM frequency formula:
http://www.ccsinfo.com/forum/viewtopic.php?t=17993
Duty cycle formula:
http://www.ccsinfo.com/forum/viewtopic.php?t=42417&start=1
PWM postscaler explanation:
http://www.ccsinfo.com/forum/viewtopic.php?t=29786&start=1
Sample code for PWM postscaler:
http://www.ccsinfo.com/forum/viewtopic.php?t=41473&start=3
Link to a PWM calculator program:
http://www.ccsinfo.com/forum/viewtopic.php?t=40450
huiching
PostPosted: Thu Mar 31, 2011 10:38 am     Reply with quote
cycle time has an equation of (1/clock)*4*t2div*(period+1).
in my program, clock = 20 MHz and period equal 255
so, cycle time = 1/20M) * 4 * 4 * 256
Is the above statement true?
PostPosted: Thu Mar 31, 2011 11:53 am     Reply with quote
You still didn't say what you're using Timer2 for.
Is it for Timer2 interrupts, or is it for hardware PWM ?
So, I can't help you.
