accessing ADFM [solved]
cerr
PostPosted: Wed Mar 23, 2011 4:34 pm     Reply with quote
Hi There,
I would like to have my a/d value read right aligned and for that I need to set ADFM to 1.
I tried following:
#include <18F87K22.h>
#device HIGH_INTS=TRUE, adc=16, ICD=TRUE
#FUSES NOWDT                      //No Watch Dog Timer
#FUSES WDT128                     //Watch Dog Timer uses 1:128 Postscale
#FUSES HSM                        //Hi-Speed crystal oscillator
#FUSES NOBROWNOUT                 //No brownout reset
#FUSES NOPLLEN                    //No PLL enabled
#FUSES BBSIZ1K                    //1K words Boot Block size
#FUSES NOXINST                    //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(clock=10000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PC, ERRORS)
#bit ADFM = ADCON2.7
void main (void)
  ADFM=1;
  int16 adcval=0;
  while (true) {
   setup_adc(ADC_CLOCK_INTERNAL | ADC_TAD_MUL_0);
   set_adc_channel(sAN0);
    delay_us(10);
    adcval=read_adc();
    fprintf(PC,"0x%4LX\r\n", adcval);
But the compiler doesn't seem to know what ADCON2 is as it says:
*** Error 12 "analog.c" Line 16(1,3): Undefined identifier
How do I get access to the ADFM config bit in the ADCON2 register?
Thanks!
MCU: PIC 18F87K22
Compiler: 4.119
cerr
PostPosted: Wed Mar 23, 2011 5:11 pm     Reply with quote
GOT IT!
Probably not the best version but it works:
//#bit ADFM = ADCON2.7
#byte ADCON2 = getenv("sfr:ADCON2")
void main (void)
  //test=1;
  int16 adcval=0;
  ADCON2|= 0x80;
  while (true) {
    delay_us(10);
    adcval=read_adc();
    fprintf(PC,"0x%x 0x%4LX\r\n", ADCON2,adcval);
