cerr
Joined: 10 Feb 2011 Posts: 241 Location: Vancouver, BC
accessing ADFM [solved] |
Posted: Wed Mar 23, 2011 4:34 pm |
Hi There,
I would like to have my a/d value read right aligned and for that I need to set ADFM to 1.
I tried following:
Code: | #include <18F87K22.h>
#device HIGH_INTS=TRUE, adc=16, ICD=TRUE
#FUSES HSM //Hi-Speed crystal oscillator
#FUSES NOPLLEN //No PLL enabled
#FUSES BBSIZ1K //1K words Boot Block size
#use delay(clock=10000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PC, ERRORS)
#bit ADFM = ADCON2.7
void main (void)
ADFM=1;
int16 adcval=0;
while (true) {
setup_adc(ADC_CLOCK_INTERNAL | ADC_TAD_MUL_0);
set_adc_channel(sAN0);
delay_us(10);
adcval=read_adc();
fprintf(PC,"0x%4LX\r\n", adcval);
But the compiler doesn't seem to know what ADCON2 is as it says:
*** Error 12 "analog.c" Line 16(1,3): Undefined identifier
How do I get access to the ADFM config bit in the ADCON2 register?
Thanks!
MCU: PIC 18F87K22
Compiler: 4.119 |
cerr
Posted: Wed Mar 23, 2011 5:11 pm |
GOT IT!
Probably not the best version but it works:
//#bit ADFM = ADCON2.7
#byte ADCON2 = getenv("sfr:ADCON2")
void main (void)
//test=1;
int16 adcval=0;
ADCON2|= 0x80;
while (true) {
delay_us(10);
adcval=read_adc();
fprintf(PC,"0x%x 0x%4LX\r\n", ADCON2,adcval);
