Optimization High/Low byte
RLScott
PostPosted: Fri Feb 25, 2011 11:59 am     Reply with quote
In the listing below, I am trying to get the most optimum 16F1824 code for the following function:
.................... unsigned int16 GetTimer1(void)
....................    unsigned int k;
....................    unsigned int16 retGetTimer1;
.................... #byte gt_low=retGetTimer1
.................... #byte gt_high=retGetTimer1+1
....................    k = TMR1H;
00BB:  MOVF   17,W
00BC:  MOVWF  37
....................    gt_low = TMR1L;
00BD:  MOVF   16,W
00BE:  MOVWF  38
....................    if(k != (gt_high=TMR1H))      //..high byte changed..
00BF:  MOVF   17,W
00C0:  MOVWF  39
00C1:  SUBWF  37,W
00C2:  BTFSC  03.2
00C3:  GOTO   0C6
....................       gt_low = TMR1L;   //..then re-read low byte
00C4:  MOVF   16,W
00C5:  MOVWF  38
....................    return retGetTimer1;
00C6:  MOVF   38,W
00C7:  MOVWF  78
00C8:  MOVF   39,W
00C9:  MOVWF  79
As you can see this is very optimum. But why was it necessary for me to resort to the #byte directives to get it? I was hoping to get the same sort of code from the following:
....................    unsigned int8 k,m,n;
00BB:  MOVF   17,W
00BC:  MOVWF  37
....................    m = TMR1L;
00BD:  MOVF   16,W
00BE:  MOVWF  38
....................    //n = TMR1H;
....................    if(k != (n=TMR1H))      //..high byte changed..
00BF:  MOVF   17,W
00C0:  MOVWF  39
00C1:  SUBWF  37,W
00C2:  BTFSC  03.2
00C3:  GOTO   0C6
....................       m = TMR1L;   //..then re-read low byte
00C4:  MOVF   16,W
00C5:  MOVWF  38
....................    return ((unsigned int16)n<<8) + m;
00C6:  CLRF   3B
00C7:  MOVF   39,W
00C8:  MOVWF  3A
00C9:  MOVWF  3B
00CA:  CLRF   3A
00CB:  MOVF   38,W
00CC:  ADDWF  3A,W
00CD:  MOVWF  78
00CE:  MOVLW  00
00CF:  ADDWFC 3B,W
00D0:  MOVWF  7A
00D1:  MOVF   7A,W
00D2:  MOVWF  79
As you can see, it is nowhere near as good as the first implementation. Is there some way I can coax the optimization of the first listing from an implementation that did not resort to such compiler-dependent constructs as #byte and and assumed endian order? (My build options are set for maximum optimization.)
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
PostPosted: Fri Feb 25, 2011 1:07 pm     Reply with quote
You can use make16() to do it efficiently:
.................... return(make16(n,m));
000E:  MOVF   n,W
000F:  MOVWF  @7A
0010:  MOVF   m,W
0011:  MOVWF  @78
0012:  MOVF   n,W
0013:  MOVWF  @79
#include <16F1824.H>
#fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT //, NOLVP
#byte TMR1H = 0x17
#byte TMR1L = 0x16
k = TMR1H;
m = TMR1L;
//n = TMR1H;
int16 result;
result = GetTimer1();
RLScott
PostPosted: Fri Feb 25, 2011 1:45 pm     Reply with quote
Thanks. That is neater than my solution.
Robert Scott
