Another serial question
jacqueskleynhans
PostPosted: Tue Feb 08, 2011 10:18 am     Reply with quote
HI Guys I have a issue reading in more than two serial bytes.
BOOLEAN waitForResponse( int32 timeout, byte buffer[], int8 bufferLength )
  int8 byteCnt = 0;
  int32 time = 0;
    while(kbhit(CAMERA)&&(++time<timeout))
      buffer[byteCnt] = fgetc(CAMERA);
      if( byteCnt == bufferLength )
        return (1);
   byteCnt++;
      return (0);
I'm reading in a total of 6 bytes of which the first two are always correct but the last four are garbage.
Any suggestions ??
Thx
"THE ONLY EASY DAY WAS YESTERDAY"
ezflyr
PostPosted: Tue Feb 08, 2011 10:25 am     Reply with quote
Yes, two suggestions:
1. Add the ERRORS directive to your #Use RS232 statement
2. Read the forum everyday as this and other similar problems are covered repeatedly here....
John
jacqueskleynhans
int_rda
PostPosted: Tue Feb 08, 2011 1:49 pm     Reply with quote
Thx I will try and set up a int driven routine.
Regards
jacqueskleynhans
PostPosted: Wed Feb 09, 2011 1:57 pm     Reply with quote
Ok I solved the problem by adding an isr for my serial bit sream that the pic receives.
