jacqueskleynhans
Joined: 10 Apr 2008 Posts: 109 Location: Cape Town, South Africa
Another serial question |
Posted: Tue Feb 08, 2011 10:18 am |
HI Guys I have a issue reading in more than two serial bytes.
Code: | BOOLEAN waitForResponse( int32 timeout, byte buffer[], int8 bufferLength )
int8 byteCnt = 0;
int32 time = 0;
while(kbhit(CAMERA)&&(++time<timeout))
buffer[byteCnt] = fgetc(CAMERA);
if( byteCnt == bufferLength )
return (1);
byteCnt++;
return (0);
I'm reading in a total of 6 bytes of which the first two are always correct but the last four are garbage.
Any suggestions ??
Thx _________________ "THE ONLY EASY DAY WAS YESTERDAY" |
ezflyr
Posted: Tue Feb 08, 2011 10:25 am |
Yes, two suggestions:
1. Add the ERRORS directive to your #Use RS232 statement
2. Read the forum everyday as this and other similar problems are covered repeatedly here....
John |
jacqueskleynhans
int_rda |
Posted: Tue Feb 08, 2011 1:49 pm |
Thx I will try and set up a int driven routine.
Regards _________________ "THE ONLY EASY DAY WAS YESTERDAY" |
jacqueskleynhans
Posted: Wed Feb 09, 2011 1:57 pm |
Ok I solved the problem by adding an isr for my serial bit sream that the pic receives. _________________ "THE ONLY EASY DAY WAS YESTERDAY" |
