glcd problem
jony john
glcd problem
PostPosted: Thu Jan 13, 2011 7:26 pm     Reply with quote
hye all,
I need help regarding to glcd please.
I use 18F452, 20MHz, glcd pin connection as below:
 GLCD Pin connections:                                            ////
//// (These can be changed as needed in the following defines).      ////
////  * 1: VSS is connected to GND                                   ////
////  * 2: VDD is connected to +5V                                   ////
////  * 3: V0 - LCD operating voltage is connected from a 20k Ohm POT////
////  * 4: D/I - Data or Instruction is connected to B2              ////
////  * 5: R/W - Read or Write is connected to B4                    ////
////  * 6: Enable is connected to B5                                 ////
////  *7-14: Data Bus 0 to 7 is connected to port d                  ////
////  *15: Chip Select 1 is connected to B0                          ////
////  *16: Chip Select 2 is connected to B1                          ////
////  *17: Reset is connected to C0                                  ////
////  *18: Negative voltage is also connected to the 20k Ohm POT     ////
////  *19: Positive voltage for LED backlight is connected to +5V    ////
////  *20: Negavtive voltage for LED backlight is connected to GND
My coding are as below:
#include <18F452.H>
#include "GLCD.c"
   //int x2=0,y2=0;
   char text[30]="HELLO WORLD";   //
   glcd_init(ON);
   glcd_fillScreen(OFF);
   //while(1)
      glcd_text57(0,0,text,1,ON);   //
      //delay_ms(1000);
What I got from simulation and hardware:
http://img714.imageshack.us/i/96204517.png
Your kind help about this matter are much appreciated.
Markdem
PostPosted: Thu Jan 13, 2011 9:39 pm     Reply with quote
You did not say if you are using the standard CCS driver, so I will assume so.
The issue here is the driver is written for 4Mhz operation. You are running is at 20Mhz, so the timings are wrong.
Have a look at the driver and you will see some "delay_cycle(1)" lines. Change the delay to the smallest number that works for you. I would start at 10 and workdown.
Maybe there is a better way to fix this, but this has always worked for me.
Mark
takumi
PostPosted: Wed Jan 19, 2011 1:56 am     Reply with quote
Tq Markdem, I've learned something from your answer. But how about a GLCD TGL12864E which didn't have any CS pins? Which driver of CCS is suitable?
1. vss
2. vdd
3. vo
4. rs
5. r/w
6. e
7. DB0
8. DB1
9. DB2
10. DB3
11. DB4
12. DB5
13. DB6
14. DB7
15. PSB
16. NC
17. /RST
18. NC
19. LEDK
20. LEDA
