		| Author | Message |
		| jony john
				| glcd problem |
				|  Posted: Thu Jan 13, 2011 7:26 pm |   |
				| hye all, I need help regarding to glcd please.
 I use 18F452, 20MHz, glcd pin connection as below:
  	  | Code: |  	  | GLCD Pin connections:                                            ////
 //// (These can be changed as needed in the following defines).      ////
 ////  * 1: VSS is connected to GND                                   ////
 ////  * 2: VDD is connected to +5V                                   ////
 ////  * 3: V0 - LCD operating voltage is connected from a 20k Ohm POT////
 ////  * 4: D/I - Data or Instruction is connected to B2              ////
 ////  * 5: R/W - Read or Write is connected to B4                    ////
 ////  * 6: Enable is connected to B5                                 ////
 ////  *7-14: Data Bus 0 to 7 is connected to port d                  ////
 ////  *15: Chip Select 1 is connected to B0                          ////
 ////  *16: Chip Select 2 is connected to B1                          ////
 ////  *17: Reset is connected to C0                                  ////
 ////  *18: Negative voltage is also connected to the 20k Ohm POT     ////
 ////  *19: Positive voltage for LED backlight is connected to +5V    ////
 ////  *20: Negavtive voltage for LED backlight is connected to GND
 My coding are as below:
 #include <18F452.H>
 #include "GLCD.c"
 //int x2=0,y2=0;
 char text[30]="HELLO WORLD";   //
 glcd_init(ON);
 glcd_fillScreen(OFF);
 //while(1)
 glcd_text57(0,0,text,1,ON);   //
 //delay_ms(1000);
 What I got from simulation and hardware:
 http://img714.imageshack.us/i/96204517.png
 Your kind help about this matter are much appreciated.
		| Markdem
				|  Posted: Thu Jan 13, 2011 9:39 pm |   |
				| You did not say if you are using the standard CCS driver, so I will assume so.
 The issue here is the driver is written for 4Mhz operation. You are running is at 20Mhz, so the timings are wrong.
 Have a look at the driver and you will see some "delay_cycle(1)" lines. Change the delay to the smallest number that works for you. I would start at 10 and workdown.
 Maybe there is a better way to fix this, but this has always worked for me.
 Mark
		| takumi
				|  Posted: Wed Jan 19, 2011 1:56 am |   |
				| Tq Markdem, I've learned something from your answer. But how about a GLCD TGL12864E which didn't have any CS pins? Which driver of CCS is suitable?
 1. vss
 2. vdd
 3. vo
 4. rs
 5. r/w
 6. e
 7. DB0
 8. DB1
 9. DB2
 10. DB3
 11. DB4
 12. DB5
 13. DB6
 14. DB7
 15. PSB
 16. NC
 17. /RST
 18. NC
 19. LEDK
 20. LEDA
