why! Tx - Rx source code not work
sorasit46
PostPosted: Mon Dec 06, 2010 5:36 pm     Reply with quote
I've searched, using the search tool and have not found a solution.
Please help.
Rx code
/* Recieved */
#include <12f675.h>
#device  adc=10
#fuses   INTRC_IO
#fuses   NOWDT
#fuses   PUT
#fuses   NOMCLR
#fuses   NOBROWNOUT
#fuses   NOCPD
#fuses   NOPROTECT
#use     delay (clock=4000000)
#byte    OSCCON = 0x8F
#define DATA     PIN_A5           // input
#define Led      PIN_A4           // output
int16 rxbit (void)                // check bit cycle
       int16 x;
       x = 0;
       while (input (DATA)==1) {x++;}
       while (input (DATA)==0) {x++;}
       return (x);
void rxpre (void)                 // check preamble
      int16 x;
      char c;
      c = 0;
      while (c<5)                 // check bit 0
             x = rxbit ();
             if (x>=33 && x<=37) c++; else c = 0;
      while (x<53) {x = rxbit ();}     // check bit 1
char rxbyte (void)                // read one byte
      char x,i;
      x = 0;
      for (i=0;i<=7;i++)
           x >>= 1;
           if (rxbit ()>53) x |= 0x80;
      return (x);
char rxrecv (void)
      char c,x ;
      rxpre ();c = rxbyte ();x = rxbyte ();
      if (c==0x240 ) return (x);  // match
void main (void)
      char x;
      disable_interrupts(GLOBAL);
      setup_adc_ports(NO_ANALOGS);
      setup_adc(ADC_OFF);
      setup_timer_1(T1_DISABLED);
      port_a_pullups(true);
      set_tris_A(0b11101111);
      OSCCON = 0x60;delay_ms(100);
      output_low (Led);
      while (true)
             x = rxrecv ();
             if (x==0x1)
                 output_high(Led);delay_ms(100);
                 output_low(Led);delay_ms(50);
Tx code
/* SEND */
#include <12f675.h>
#fuses INTRC_IO
#fuses NOWDT
#fuses PUT
#fuses NOMCLR
#fuses NOBROWNOUT
#fuses NOCPD
#fuses NOPROTECT
#byte  OSCCON = 0x8F
#define DATA     PIN_A4           // output
#define LED      PIN_A0           // output
#define Send     PIN_A1           // input
void tx0 (void)                   // send bit 0
      output_high (DATA);delay_us (250);
      output_low (DATA);delay_us (250);
void tx1 (void)                   // send bit 1
      output_high (DATA);delay_us (500);
      output_low (DATA);delay_us (500);
void txbyte (char x)              // send one byte
      char i;
      for (i=0;i<=7;i++)
           if ((x & 1)==1) tx1 (); else tx0 ();
           x >>= 1;
void txsend (char x)
      txbyte (0);txbyte (0);      // preamble
      tx1 ();                     // start
      txbyte (0x240);             // code 1
      txbyte (x);                 // command
      tx0 ();                     // end
      output_high (LED);delay_ms (100);
      output_low (LED);
void main (void)
      setup_adc(ADC_OFF);
      set_tris_A(0b11101110);
      output_low (LED);
      OSCCON = 0x60;
      delay_ms(20);
      while (true)
            {if (input (Send)==0) {txsend (0x1);delay_ms(500);}}
Thanks for the help!
vinniewryan
PostPosted: Mon Dec 06, 2010 7:10 pm     Reply with quote
What is your compiler version?
What isn't working?
Have you tried to run a simple test program using this mcu?
Vinnie Ryan
ezflyr
PostPosted: Mon Dec 06, 2010 9:15 pm     Reply with quote
First you need to have a strategy to debug stuff like this on your own. It's your project and no one is going to take a greater interest in it than you! Also, you've got all the hardware right in front of you, so you have a significant advantage over a bunch of random folks on an internet forum!
Having said that, you need a way to find out what is going on inside the PIC. I have found it handy to have a serial LCD that I can connect to a spare pin and use to display diagnostic messages. Sometimes this doesn't always work in time critical sections of the code, but it may be a start. You can also get creative with extra LEDs to help debug what is going on. You also really need to look at how your PIC chips are connected - is there a common GND between them, for instance. Next, take small steps in the problem (for example, can the Tx output a single bit and can it be received by the RX?) and build toward the final solution.
Frankly, your code needs a lot of work. Most of the setup stuff is unnecessary, as is the use of TRIS (you aren't using Fast IO). I also noticed that you define OSCCON differently in each program - 0x08F and 0x8F. Not sure why you are doing that in the first place, but it is a discrepancy.
John
sorasit46
PostPosted: Tue Dec 07, 2010 2:57 am     Reply with quote
ezflyr wrote:
John
Now! I using Fast IO & define OSCCON in each program - 0x8F.
But It's not work.
My compiler is PCWHD IDE 4.057.
Wayne_
PostPosted: Tue Dec 07, 2010 3:00 am     Reply with quote
First problem.
I actually expect this does not even compile, you should post the compiler error messages and warnings if there are any!
char rxrecv (void)
      char c,x ;
      rxpre ();
      c = rxbyte ();
      x = rxbyte ();
      if (c == 0x240)
I have made it more readable by seperating the lines, Can YOU spot the error ?
This routine only returns a value if c == 0x240. You need another return(0); statement at the end.
Wayne_
PostPosted: Tue Dec 07, 2010 3:18 am     Reply with quote
And another problem Smile, this is funny Smile, an honest mistake...
char rxrecv (void)
      char c,x ;
The same problem lies in the tx routine.
What value is 0x240 ? lol. What size is c ?
I expect because the error is in both it would not affect the working of your code.
sorasit46
PostPosted: Tue Dec 07, 2010 7:49 pm     Reply with quote
I'm trying to recheck.
sorasit46
PostPosted: Sat Dec 11, 2010 5:26 am     Reply with quote
My mistake in this code.
int16 x;
char c;
c = 0;
x = rxbit ();
if (x>=66 && x<=74) c++; else c = 0;
while (x<106) {x = rxbit ();} // check bit 1
char x,i;
x = 0;
for (i=0;i<=7;i++)
x >>= 1;
if (rxbit ()>106) x |= 0x80;
return (x);
