sorasit46
why! Tx - Rx source code not work |
Posted: Mon Dec 06, 2010 5:36 pm |
I've searched, using the search tool and have not found a solution.
Please help.
Rx code
Code: | /* Recieved */
#include <12f675.h>
#device adc=10
#fuses INTRC_IO
#fuses NOWDT
#fuses PUT
#fuses NOMCLR
#fuses NOBROWNOUT
#fuses NOCPD
#fuses NOPROTECT
#use delay (clock=4000000)
#byte OSCCON = 0x8F
#define DATA PIN_A5 // input
#define Led PIN_A4 // output
int16 rxbit (void) // check bit cycle
int16 x;
x = 0;
while (input (DATA)==1) {x++;}
while (input (DATA)==0) {x++;}
return (x);
void rxpre (void) // check preamble
int16 x;
char c;
c = 0;
while (c<5) // check bit 0
x = rxbit ();
if (x>=33 && x<=37) c++; else c = 0;
while (x<53) {x = rxbit ();} // check bit 1
char rxbyte (void) // read one byte
char x,i;
x = 0;
for (i=0;i<=7;i++)
x >>= 1;
if (rxbit ()>53) x |= 0x80;
return (x);
char rxrecv (void)
char c,x ;
rxpre ();c = rxbyte ();x = rxbyte ();
if (c==0x240 ) return (x); // match
void main (void)
char x;
disable_interrupts(GLOBAL);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_timer_1(T1_DISABLED);
port_a_pullups(true);
set_tris_A(0b11101111);
OSCCON = 0x60;delay_ms(100);
output_low (Led);
while (true)
x = rxrecv ();
if (x==0x1)
output_high(Led);delay_ms(100);
output_low(Led);delay_ms(50);
Tx code
Code: | /* SEND */
#include <12f675.h>
#fuses INTRC_IO
#fuses NOWDT
#fuses PUT
#fuses NOMCLR
#fuses NOBROWNOUT
#fuses NOCPD
#fuses NOPROTECT
#byte OSCCON = 0x8F
#define DATA PIN_A4 // output
#define LED PIN_A0 // output
#define Send PIN_A1 // input
void tx0 (void) // send bit 0
output_high (DATA);delay_us (250);
output_low (DATA);delay_us (250);
void tx1 (void) // send bit 1
output_high (DATA);delay_us (500);
output_low (DATA);delay_us (500);
void txbyte (char x) // send one byte
char i;
for (i=0;i<=7;i++)
if ((x & 1)==1) tx1 (); else tx0 ();
x >>= 1;
void txsend (char x)
txbyte (0);txbyte (0); // preamble
tx1 (); // start
txbyte (0x240); // code 1
txbyte (x); // command
tx0 (); // end
output_high (LED);delay_ms (100);
output_low (LED);
void main (void)
setup_adc(ADC_OFF);
set_tris_A(0b11101110);
output_low (LED);
OSCCON = 0x60;
delay_ms(20);
while (true)
{if (input (Send)==0) {txsend (0x1);delay_ms(500);}}
Thanks for the help!
vinniewryan
Posted: Mon Dec 06, 2010 7:10 pm |
What is your compiler version?
What isn't working?
Have you tried to run a simple test program using this mcu? _________________ Vinnie Ryan |
ezflyr
Posted: Mon Dec 06, 2010 9:15 pm |
First you need to have a strategy to debug stuff like this on your own. It's your project and no one is going to take a greater interest in it than you! Also, you've got all the hardware right in front of you, so you have a significant advantage over a bunch of random folks on an internet forum!
Having said that, you need a way to find out what is going on inside the PIC. I have found it handy to have a serial LCD that I can connect to a spare pin and use to display diagnostic messages. Sometimes this doesn't always work in time critical sections of the code, but it may be a start. You can also get creative with extra LEDs to help debug what is going on. You also really need to look at how your PIC chips are connected - is there a common GND between them, for instance. Next, take small steps in the problem (for example, can the Tx output a single bit and can it be received by the RX?) and build toward the final solution.
Frankly, your code needs a lot of work. Most of the setup stuff is unnecessary, as is the use of TRIS (you aren't using Fast IO). I also noticed that you define OSCCON differently in each program - 0x08F and 0x8F. Not sure why you are doing that in the first place, but it is a discrepancy.
John |
sorasit46
Posted: Tue Dec 07, 2010 2:57 am |
ezflyr wrote: | Hi,
John |
Now! I using Fast IO & define OSCCON in each program - 0x8F.
But It's not work.
My compiler is PCWHD IDE 4.057. |
Wayne_
Posted: Tue Dec 07, 2010 3:00 am |
First problem.
I actually expect this does not even compile, you should post the compiler error messages and warnings if there are any!
char rxrecv (void)
char c,x ;
rxpre ();
c = rxbyte ();
x = rxbyte ();
if (c == 0x240)
I have made it more readable by seperating the lines, Can YOU spot the error ?
This routine only returns a value if c == 0x240. You need another return(0); statement at the end. |
Wayne_
Posted: Tue Dec 07, 2010 3:18 am |
And another problem , this is funny , an honest mistake...
char rxrecv (void)
char c,x ;
The same problem lies in the tx routine.
What value is 0x240 ? lol. What size is c ?
I expect because the error is in both it would not affect the working of your code. |
sorasit46
Posted: Tue Dec 07, 2010 7:49 pm |
I'm trying to recheck. |
sorasit46
Posted: Sat Dec 11, 2010 5:26 am |
My mistake in this code.
int16 x;
char c;
c = 0;
x = rxbit ();
if (x>=66 && x<=74) c++; else c = 0;
while (x<106) {x = rxbit ();} // check bit 1
char x,i;
x = 0;
for (i=0;i<=7;i++)
x >>= 1;
if (rxbit ()>106) x |= 0x80;
return (x);
