karthickiw
Problem with External eeprom... |
Posted: Wed Jun 24, 2009 9:21 am |
Dear CCS Friends,
I write a program for write and read the string in external eeprom. After finished my code, I write the three string data in specified locations. After that I read one by one location, I received wrong data for (17*13) location and other location data are correct.
#include "2464.c"
void write_ext(long int add,char data[])
long int loc=0;
for (loc = 0; loc <= strlen(data); loc++)
if ( loc < strlen(data)) write_ext_eeprom((loc+add), data[loc]);
else write_ext_eeprom((loc+add), '\0');
void read_ext(long int add)
long int loc=0;
char data[];
for (loc = 0; loc < 13; loc++)
if (read_ext_eeprom(loc+add)=='\0')
data[loc]=read_ext_eeprom(loc+add);
printf("%S\n\r",data);
char name[15];
long int j=0;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
//Setup_Oscillator parameter not selected from Intr Oscillotar Config tab
printf("Start...\n\r");
init_ext_eeprom();
delay_ms(20);
sprintf(name,"%s","Programmer");
write_ext(15*13,name);
delay_ms(20);
sprintf(name,"%s","Karthic");
write_ext(16*13,name);
delay_ms(20);
sprintf(name,"%s","Welcome");
write_ext(17*13,name);
delay_ms(20);
while(true)
read_ext((15*13));
read_ext((16*13));
read_ext((17*13));
For my program I received below answer in hyper terminal.
Quote: | Start….
Programmer
Karthic
Karthic
I using PIC18LF452 controller and 24C64 EEPROM.
Please check my code and give idea for my problem...
two question regarding 24C64 IC
1) How many byte is store in 24C64 eeprom?. i see the datasheet, but have little confusion.
2) i want to store the 4MB of data, for that what type of memory is used?. Please give any suggestion . |
Posted: Wed Jun 24, 2009 11:21 am |
How much storage do you expect to be assigned by CCS C with this variable definition?
mkuang
Re: Problem with External eeprom... |
Posted: Wed Jun 24, 2009 11:24 am |
The part has 64kbit or 8 kbytes of storage. You would likely address it using a number from zero to 7999. Your function declaration here is not correct:
If you want a function to accept an array as an input you have to declare a pointer to the first element of the array like:
void write_ext(long int add,char* data)
Posted: Wed Jun 24, 2009 12:26 pm |
Quote: | You would likely address it using a number from zero to 7999 |
The size numbers in the eeprom data sheet are binary, not decimal.
It has 8192 bytes. The address range is from 0 to 8191.
Quote: | Your function declaration here is not correct: |
In fact, it works fine. The test program shown below displays the
following output:
Code: | #include <16F877.H>
void write_ext(long int add, char data[])
printf("%s", data);
int8 buffer[32];
strcpy(buffer, "Hello World");
write_ext(0, buffer);
karthickiw
Full actual Program |
Posted: Wed Jun 24, 2009 12:39 pm |
Dear Friends,
Thank you for your idea, but still I have a problem during read the 17*13 location...
#include <18F452.h>
#device adc=8
#include <string.h>
#FUSES XT //High speed Osc (> 4mhz)
#FUSES PROTECT //Code protected from reads
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES WRT //Program Memory Write Protected
#FUSES WRTD //Data EEPROM write protected
#FUSES WRTB //Boot block write protected
#FUSES WRTC //configuration registers write protected
#FUSES CPD //Data EEPROM Code Protected
#FUSES CPB //Boot Block Code Protected
#FUSES EBTR //Memory protected from table reads
#FUSES EBTRB //Boot block protected from table reads
#include "2464.c"
long int loc=0;
long int loc=0;
char data[];
char name[15];
long int j=0;
setup_adc(ADC_OFF);
setup_wdt(WDT_OFF);
printf("Start...");
init_ext_eeprom();
delay_ms(20);
////////////////////////12 character size without null///////////////////////
sprintf(name,"%s","Erode");
write_ext(0,name);
sprintf(name,"%s","Savitha");
write_ext(1*13,name);
sprintf(name,"%s","PS Park");
write_ext(2*13,name);
sprintf(name,"%s","GH");
write_ext(3*13,name);
sprintf(name,"%s","Sathiyam Hos");
write_ext(4*13,name);
sprintf(name,"%s","Collector of");
write_ext(5*13,name);
sprintf(name,"%s","Kumalan kutt");
write_ext(6*13,name);
sprintf(name,"%s","palayapalaya");
write_ext(7*13,name);
sprintf(name,"%s","Veer Palayam");
write_ext(8*13,name);
sprintf(name,"%s","Sengotampala");
write_ext(9*13,name);
sprintf(name,"%s","Thindal");
write_ext(10*13,name);
sprintf(name,"%s","Thindal medu");
write_ext(11*13,name);
sprintf(name,"%s","Pavalathan p");
write_ext(12*13,name);
sprintf(name,"%s","Veppanpalaya");
write_ext(13*13,name);
sprintf(name,"%s","Mettukadai");
write_ext(14*13,name);
sprintf(name,"%s","Vannankattu");
sprintf(name,"%s","Moolakkarai");
sprintf(name,"%s","Sathiramput");
sprintf(name,"%s","Koorapalayam");
write_ext(18*13,name);
sprintf(name,"%s","Vaaikkalmedu");
write_ext(19*13,name);
sprintf(name,"%s","Maharaja col");
write_ext(20*13,name);
sprintf(name,"%s","Kanthampalay");
write_ext(21*13,name);
sprintf(name,"%s","Police stati");
write_ext(22*13,name);
sprintf(name,"%s","Perundurai");
write_ext(23*13,name);
while(True)
read_ext((j*13));
output_high(pin_a0);
output_low(pin_a0);
j++;
if (j==24) j=0;
}// while
output from hyper terminal
Quote: | Start...Erode
Savitha
PS Park
GH
Sathiyam Hos
Collector of
Kumalan kutt
palayapalaya
Veer Palayam
Sengotampala
Thindal
Thindal medu
Pavalathan p
Veppanpalaya
Mettukadai
Vannankattu
Moolakkarai
Moolakkarai --->This is problem string (actual here present Sathiramput)
Koorapalayam
Vaaikkalmedu
Maharaja col
Kanthampalay
Police stati
Perundurai | ![Crying or Very sad](images/smiles/icon_cry.gif) |
Posted: Wed Jun 24, 2009 12:41 pm |
Start….
Programmer
Karthic
Karthic
So apparently your complaint is that it's repeating "Karthic" instead
of displaying "Welcome" ? Post some more of the output. Does it
only display "Karthic" after the initial lines ?
Post your #fuses statement. |
mkuang
Posted: Wed Jun 24, 2009 12:59 pm |
That and he is getting the same string at 17*13 as 16*13 for some reason. Going back this looks a bit fishy:
long int loc=0;
char data[];
I don't know whether you can allocated memory for an array without telling the compiler how big the array is. I would try something like:
char data[23]; //is that how many names you have there?
Posted: Wed Jun 24, 2009 1:03 pm |
long int loc=0;
char data[];
I agree. He's writing to an array which doesn't have any RAM allocated
for it, because the size was not specified. He is likely to be over-writing
other RAM locations. |
Posted: Wed Jun 24, 2009 4:45 pm |
Yes, it's been said, but he doesn't hear. |
karthickiw
Problem not solve... |
Posted: Wed Jun 24, 2009 8:49 pm |
Thank you PCM,FvM and mkuang. now i specified the array size in read_ex function, then also my problem is not solved..
Code: | void read_ext(long int add)
long int loc=0;
char data[15];
my output is
Code: | Start...Erode
Savitha
PS Park
GH
Sathiyam Hos
Collector of
Kumalan kutt
palayapalaya
Veer Palayam
Sengotampala
Thindal
Thindal medu
Pavalathan p
Veppanpalaya
Mettukadai
Vannankattu
Moolakkarai
Moolakkarai --->This is probelm string( actual here present Sathiramput)
Koorapalayam
Vaaikkalmedu
Maharaja col
Kanthampalay
Police stati
Perundurai |
[quote="PCM programmer"] Quote: | Going back this looks a bit fishy:
long int loc=0;
char data[];
other RAM locations. | ![Crying or Very sad](images/smiles/icon_cry.gif) |
Posted: Wed Jun 24, 2009 9:55 pm |
Are you running this test in actual hardware or are you running it in
Proteus or ISIS or something like that ? |
karthickiw
response |
Posted: Thu Jun 25, 2009 5:50 am |
PCM programmer wrote: | Are you running this test in actual hardware or are you running it in
im running program in hardware and when i add printf statement like below code means, im get correct output....
printf("%s",name); ---> when add this line, my result is correct.when remove means i get wrong result
Savitha
PS Park
GH
Sathiyam Hos
Collector of
Kumalan kutt
palayapalaya
Veer Palayam
Sengotampala
Thindal
Thindal medu
Pavalathan p
Veppanpalaya
Mettukadai
Vannankattu
Moolakkarai
Sathiramput --->this is correct result, when remove the printf i get Moolakkarai for this sathiramput
Koorapalayam
Vaaikkalmedu
Maharaja col
Kanthampalay
Police stati
Perundurai |
please give correct solution for this probelm.. ![Crying or Very sad](images/smiles/icon_cry.gif) |
Posted: Thu Jun 25, 2009 7:06 am |
The text should be printed twice now. Is the second copy (from read_ext)also correct? |
karthickiw
thank you |
Posted: Thu Jun 25, 2009 8:23 am |
FvM wrote: | The text should be printed twice now. Is the second copy (from read_ext)also correct? |
Text printed twice time. Second copy also correct. |
Posted: Thu Jun 25, 2009 1:56 pm |
You said "Thank You". Does that mean the problem is solved ?
Is it working OK ?
If not, then post your compiler version. |
