Problem with External eeprom...
Goto page 1, 2  Next
karthickiw
PostPosted: Wed Jun 24, 2009 9:21 am     Reply with quote
Dear CCS Friends,
I write a program for write and read the string in external eeprom. After finished my code, I write the three string data in specified locations. After that I read one by one location, I received wrong data for (17*13) location and other location data are correct.
#include "2464.c"
void write_ext(long int add,char data[])
long int loc=0;
 for (loc = 0; loc <= strlen(data); loc++)
       if ( loc < strlen(data)) write_ext_eeprom((loc+add), data[loc]);
       else write_ext_eeprom((loc+add), '\0');
void read_ext(long int add)
long int loc=0;
char data[];
for (loc = 0; loc < 13; loc++)
       if (read_ext_eeprom(loc+add)=='\0')
       data[loc]=read_ext_eeprom(loc+add);
printf("%S\n\r",data);
char name[15];
long int j=0;
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
//Setup_Oscillator parameter not selected from Intr Oscillotar Config tab
 printf("Start...\n\r");
 init_ext_eeprom();
 delay_ms(20);
sprintf(name,"%s","Programmer");
write_ext(15*13,name);
delay_ms(20);
sprintf(name,"%s","Karthic");
write_ext(16*13,name);
delay_ms(20);
sprintf(name,"%s","Welcome");
write_ext(17*13,name);
delay_ms(20);
while(true)
read_ext((15*13));
read_ext((16*13));
read_ext((17*13));
For my program I received below answer in hyper terminal.
Start….
Programmer
Karthic
Karthic
I using PIC18LF452 controller and 24C64 EEPROM.
Please check my code and give idea for my problem... Crying or Very sad
two question regarding 24C64 IC
1) How many byte is store in 24C64 eeprom?. i see the datasheet, but have little confusion.
2) i want to store the 4MB of data, for that what type of memory is used?. Please give any suggestion .
PostPosted: Wed Jun 24, 2009 11:21 am     Reply with quote
How much storage do you expect to be assigned by CCS C with this variable definition?
char data[];
mkuang
Re: Problem with External eeprom...
PostPosted: Wed Jun 24, 2009 11:24 am     Reply with quote
The part has 64kbit or 8 kbytes of storage. You would likely address it using a number from zero to 7999. Your function declaration here is not correct:
If you want a function to accept an array as an input you have to declare a pointer to the first element of the array like:
void write_ext(long int add,char* data)
PostPosted: Wed Jun 24, 2009 12:26 pm     Reply with quote
The size numbers in the eeprom data sheet are binary, not decimal.
It has 8192 bytes. The address range is from 0 to 8191.
In fact, it works fine. The test program shown below displays the
following output:
Hello World
#include <16F877.H>
void write_ext(long int add, char data[])
printf("%s", data);
int8 buffer[32];
strcpy(buffer, "Hello World");
write_ext(0, buffer);
karthickiw
Full actual Program
PostPosted: Wed Jun 24, 2009 12:39 pm     Reply with quote
Dear Friends,
Thank you for your idea, but still I have a problem during read the 17*13 location...
#include <18F452.h>
#device adc=8
#include <string.h>
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES XT                       //High speed Osc (> 4mhz)
#FUSES PROTECT                  //Code protected from reads
#FUSES NOOSCSEN                 //Oscillator switching is disabled, main oscillator is source
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES PUT                      //Power Up Timer
#FUSES NOLVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES WRT                      //Program Memory Write Protected
#FUSES WRTD                     //Data EEPROM write protected
#FUSES WRTB                     //Boot block write protected
#FUSES WRTC                     //configuration registers write protected
#FUSES CPD                      //Data EEPROM Code Protected
#FUSES CPB                      //Boot Block Code Protected
#FUSES EBTR                     //Memory protected from table reads
#FUSES EBTRB                    //Boot block protected from table reads
#include "2464.c"
long int loc=0;
long int loc=0;
char data[];
char name[15];
long int j=0;
   setup_adc(ADC_OFF);
   setup_wdt(WDT_OFF);
 printf("Start...");
 init_ext_eeprom();
 delay_ms(20);
////////////////////////12 character size without null///////////////////////
sprintf(name,"%s","Erode");
write_ext(0,name);
sprintf(name,"%s","Savitha");
write_ext(1*13,name);
sprintf(name,"%s","PS Park");
write_ext(2*13,name);
sprintf(name,"%s","GH");
write_ext(3*13,name);
sprintf(name,"%s","Sathiyam Hos");
write_ext(4*13,name);
sprintf(name,"%s","Collector of");
write_ext(5*13,name);
sprintf(name,"%s","Kumalan kutt");
write_ext(6*13,name);
sprintf(name,"%s","palayapalaya");
write_ext(7*13,name);
sprintf(name,"%s","Veer Palayam");
write_ext(8*13,name);
sprintf(name,"%s","Sengotampala");
write_ext(9*13,name);
sprintf(name,"%s","Thindal");
write_ext(10*13,name);
sprintf(name,"%s","Thindal medu");
write_ext(11*13,name);
sprintf(name,"%s","Pavalathan p");
write_ext(12*13,name);
sprintf(name,"%s","Veppanpalaya");
write_ext(13*13,name);
sprintf(name,"%s","Mettukadai");
write_ext(14*13,name);
sprintf(name,"%s","Vannankattu");
sprintf(name,"%s","Moolakkarai");
sprintf(name,"%s","Sathiramput");
sprintf(name,"%s","Koorapalayam");
write_ext(18*13,name);
sprintf(name,"%s","Vaaikkalmedu");
write_ext(19*13,name);
sprintf(name,"%s","Maharaja col");
write_ext(20*13,name);
sprintf(name,"%s","Kanthampalay");
write_ext(21*13,name);
sprintf(name,"%s","Police stati");
write_ext(22*13,name);
sprintf(name,"%s","Perundurai");
write_ext(23*13,name);
   while(True)
    read_ext((j*13));
    output_high(pin_a0);
     output_low(pin_a0);
     j++;
if (j==24) j=0;
   }// while
output from hyper terminal
Start...Erode
Savitha
PS Park
GH
Sathiyam Hos
Collector of
Kumalan kutt
palayapalaya
Veer Palayam
Sengotampala
Thindal
Thindal medu
Pavalathan p
Veppanpalaya
Mettukadai
Vannankattu
Moolakkarai
Moolakkarai --->This is problem string (actual here present Sathiramput)
Koorapalayam
Vaaikkalmedu
Maharaja col
Kanthampalay
Police stati
Perundurai
Crying or Very sad
PostPosted: Wed Jun 24, 2009 12:41 pm     Reply with quote
Start….
Programmer
Karthic
Karthic
So apparently your complaint is that it's repeating "Karthic" instead
of displaying "Welcome" ? Post some more of the output. Does it
only display "Karthic" after the initial lines ?
Post your #fuses statement.
mkuang
PostPosted: Wed Jun 24, 2009 12:59 pm     Reply with quote
That and he is getting the same string at 17*13 as 16*13 for some reason. Going back this looks a bit fishy:
long int loc=0;
char data[];
I don't know whether you can allocated memory for an array without telling the compiler how big the array is. I would try something like:
char data[23]; //is that how many names you have there?
PostPosted: Wed Jun 24, 2009 1:03 pm     Reply with quote
long int loc=0;
char data[];
I agree. He's writing to an array which doesn't have any RAM allocated
for it, because the size was not specified. He is likely to be over-writing
other RAM locations.
PostPosted: Wed Jun 24, 2009 4:45 pm     Reply with quote
Yes, it's been said, but he doesn't hear.
karthickiw
Problem not solve...
PostPosted: Wed Jun 24, 2009 8:49 pm     Reply with quote
Thank you PCM,FvM and mkuang. now i specified the array size in read_ex function, then also my problem is not solved..
long int loc=0;
char data[15];
my output is
Start...Erode
Savitha
PS Park
GH
Sathiyam Hos
Collector of
Kumalan kutt
palayapalaya
Veer Palayam
Sengotampala
Thindal
Thindal medu
Pavalathan p
Veppanpalaya
Mettukadai
Vannankattu
Moolakkarai
Moolakkarai --->This is probelm string( actual here present Sathiramput)
Koorapalayam
Vaaikkalmedu
Maharaja col
Kanthampalay
Police stati
Perundurai
[quote="PCM programmer"]
long int loc=0;
char data[];
Crying or Very sad Crying or Very sad
PostPosted: Wed Jun 24, 2009 9:55 pm     Reply with quote
Are you running this test in actual hardware or are you running it in
Proteus or ISIS or something like that ?
karthickiw
response
PostPosted: Thu Jun 25, 2009 5:50 am     Reply with quote
im running program in hardware and when i add printf statement like below code means, im get correct output....
printf("%s",name); ---> when add this line, my result is correct.when remove means i get wrong result
Start...Erode
Savitha
PS Park
GH
Sathiyam Hos
Collector of
Kumalan kutt
palayapalaya
Veer Palayam
Sengotampala
Thindal
Thindal medu
Pavalathan p
Veppanpalaya
Mettukadai
Vannankattu
Moolakkarai
Sathiramput --->this is correct result, when remove the printf i get Moolakkarai for this sathiramput
Koorapalayam
Vaaikkalmedu
Maharaja col
Kanthampalay
Police stati
Perundurai
please give correct solution for this probelm.. Crying or Very sad
PostPosted: Thu Jun 25, 2009 7:06 am     Reply with quote
The text should be printed twice now. Is the second copy (from read_ext)also correct?
karthickiw
thank you
PostPosted: Thu Jun 25, 2009 8:23 am     Reply with quote
Text printed twice time. Second copy also correct.
PostPosted: Thu Jun 25, 2009 1:56 pm     Reply with quote
You said "Thank You". Does that mean the problem is solved ?
Is it working OK ?
If not, then post your compiler version.
Goto page 1, 2  Next
Page 1 of 2
