#int_rda and Long Packet
kmp84
PostPosted: Sun Sep 05, 2010 2:39 am     Reply with quote
Hi Programmers...
I have project with 2 serial isr (#int_rda and #int_ext) for rs_485 communication and rf_id reader GP20model. My project work good, but when send long packet i.e 50 - 100 bytes to pic16F628A it block if I use #locate directive for GP20_buffer or clear buffer_gp20 without use #locate directive. Any suggestion about this problem ?
My compiler ver. is PCM v.4.104
Thanks before:)
Here is my code
   #include <16F628A.h>
   #fuses HS, NOWDT,PROTECT,BROWNOUT,PUT,NOLVP,MCLR  ////////////////////////////////////////////
   // #use delay(clock=11 059 200)       //new version v.0.2                                   //
   #use delay(clock=10 000 000)          //old version v.0.1                                   //
   #use rs232(baud=9600,rcv=PIN_B1,xmit=PIN_B2,errors,enable=PIN_B3,STREAM=rs_485,DISABLE_INTS)//
   #use rs232(baud=9600,rcv=PIN_B0,INVERT,STREAM=GP_20,DISABLE_INTS)                           //
   ///////////////////////// standart_bytes//////////////////////////////////////////////////////
   #define stx_rx               0xd2     // Start_byte of received packet
   #define etx_rx               0xd3     // Stop_byte  of received packe
   #define stx_tx               0xc2     //
   #define etx_tx               0xc3     //
   #define cop_send_id_tx       0x94     //
   #define buffer_size_GP20       14
   #define buffer_size_485_tx     16
   #define buffer_size_485_rx      7
   #define r_led   PIN_A1
   #define g_led   PIN_A0
#priority ext,rda
   // Global variable //
   int   buffer_485_tx    [buffer_size_485_tx];
   int   buffer_485_rx    [buffer_size_485_rx];
    //#locate buffer_485  = 0x70
   int   buffer_GP20  [buffer_size_GP20];
    //#locate buffer_GP20 = 0x20
   int1  packet;
   int   index_485_rx;
   int   index_gp20;
   int   x;
   int   address =0xff;
   int   err=0xad;
   int   w=0;
#int_ext
   void EXT_GP20_isr()                      // ext_Gp20 interrupt receiver func;
      buffer_GP20[index_gp20] = fgetc(GP_20);
      if(++index_gp20 == buffer_size_GP20)
         index_gp20 = 0;
         set_timer2(46528);
         clear_interrupt(int_TIMER2);
         enable_interrupts(int_TIMER2);
      if (buffer_GP20 [0]==0x02 && buffer_GP20 [13]==0x03)
         clear_interrupt(int_TIMER0);
         enable_interrupts(int_TIMER0);
         output_high (r_led);
         output_low (g_led);
#int_TIMER0
   void timer_0_isr ()
      w++;
      if (w>2)
        index_gp20 = 0;
      if (w>30)    //  && buffer_GP20 [2] == 0x00
         disable_interrupts(int_TIMER0);
         output_high (g_led);
         output_low (r_led);
         w=0;
#int_timer1
   void TIMER1_isr()
      disable_interrupts(int_TIMER1);
      packet=1;
      index_485_rx =0;
#int_rda
   void rs485_isr ()
   {  x = fgetc(rs_485);
      if(!packet)
      {  buffer_485_rx[index_485_rx] = x;
         if(++index_485_rx == buffer_485_rx)
             index_485_rx =0;
             set_timer1(46528);//->> 65536-((16.5*XTAL_FREQ)/BAUDRATE)
             clear_interrupt(int_TIMER1);
             enable_interrupts(int_TIMER1);
///////////////////////"Main_Function"////////////////////////////////////////////
void main ()
      index_gp20 = 0;
      //init_tx_buffer ();
      packet=0;
      index_485_rx=0;
      index_gp20=0;
      w=0;
      setup_vref(FALSE);
      setup_timer_0(T0_INTERNAL|T0_DIV_256);
      setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
      //setup_timer_2 ( T2_DIV_BY_4, 0xc0, 2);
      enable_interrupts(INT_EXT_L2H );
      enable_interrupts(int_rda);
      enable_interrupts(global);
      port_b_pullups (TRUE);
      delay_ms (150);
      clr_gp20_buffer();
      get_address ();
      fprintf (rs_485,"address:%d",address);
      output_low (r_led);
      output_low (g_led);
while (TRUE){
   if (get_packet())
      switch (buffer_485_rx [2])
          case 0x22: {
                       fprintf (rs_485,"state_1");
          case 0x33 :{
                       clr_gp20_buffer ();
          case 0x55 :{
                        if (check_gp20_buff ())
                           send_packet();
                        }else fputc (err,rs_485);
PostPosted: Sun Sep 05, 2010 3:14 am     Reply with quote
#int_rda
void rs485_isr ()
x = fgetc(rs_485);
if(!packet)
index_485_rx =0;
This whole thing you're doing here is a mistake. Avoid doing address
tricks. They're unnecessary, and they're left-over from hacker days as
an ASM programmer. When you go to C, all that stuff should be left
behind.
Look at the CCS example file, Ex_sisr.c. It shows how to do an circular
buffer in #int_rda. Here's the file location:
c:\program files\picc\examples\ex_sisr.c
PostPosted: Sun Sep 05, 2010 3:23 am     Reply with quote
Also, add #device *=16. This way your processor can use the whole address range of the 628, rather than being stuck with just the low page.
kmp84
PostPosted: Tue Sep 07, 2010 6:54 am     Reply with quote
#int_rda
void rs485_isr ()
x = fgetc(rs_485);
if(!packet)
index_485_rx =0;
behind.
Thanks PCM ..!
My mistake was little stupid, but now I corrected, and project work well.
correction:
 if(++index_485_rx == buffer_size_485_rx)
             index_485_rx =0;
