kmp84
#int_rda and Long Packet |
Posted: Sun Sep 05, 2010 2:39 am |
Hi Programmers...
I have project with 2 serial isr (#int_rda and #int_ext) for rs_485 communication and rf_id reader GP20model. My project work good, but when send long packet i.e 50 - 100 bytes to pic16F628A it block if I use #locate directive for GP20_buffer or clear buffer_gp20 without use #locate directive. Any suggestion about this problem ?
My compiler ver. is PCM v.4.104
Thanks before:)
Here is my code
#include <16F628A.h>
#fuses HS, NOWDT,PROTECT,BROWNOUT,PUT,NOLVP,MCLR ////////////////////////////////////////////
// #use delay(clock=11 059 200) //new version v.0.2 //
#use delay(clock=10 000 000) //old version v.0.1 //
#use rs232(baud=9600,rcv=PIN_B1,xmit=PIN_B2,errors,enable=PIN_B3,STREAM=rs_485,DISABLE_INTS)//
#use rs232(baud=9600,rcv=PIN_B0,INVERT,STREAM=GP_20,DISABLE_INTS) //
///////////////////////// standart_bytes//////////////////////////////////////////////////////
#define stx_rx 0xd2 // Start_byte of received packet
#define etx_rx 0xd3 // Stop_byte of received packe
#define stx_tx 0xc2 //
#define etx_tx 0xc3 //
#define cop_send_id_tx 0x94 //
#define buffer_size_GP20 14
#define buffer_size_485_tx 16
#define buffer_size_485_rx 7
#define r_led PIN_A1
#define g_led PIN_A0
#priority ext,rda
// Global variable //
int buffer_485_tx [buffer_size_485_tx];
int buffer_485_rx [buffer_size_485_rx];
//#locate buffer_485 = 0x70
int buffer_GP20 [buffer_size_GP20];
//#locate buffer_GP20 = 0x20
int1 packet;
int index_485_rx;
int index_gp20;
int x;
int address =0xff;
int err=0xad;
int w=0;
#int_ext
void EXT_GP20_isr() // ext_Gp20 interrupt receiver func;
buffer_GP20[index_gp20] = fgetc(GP_20);
if(++index_gp20 == buffer_size_GP20)
index_gp20 = 0;
set_timer2(46528);
clear_interrupt(int_TIMER2);
enable_interrupts(int_TIMER2);
if (buffer_GP20 [0]==0x02 && buffer_GP20 [13]==0x03)
clear_interrupt(int_TIMER0);
enable_interrupts(int_TIMER0);
output_high (r_led);
output_low (g_led);
#int_TIMER0
void timer_0_isr ()
w++;
if (w>2)
index_gp20 = 0;
if (w>30) // && buffer_GP20 [2] == 0x00
disable_interrupts(int_TIMER0);
output_high (g_led);
output_low (r_led);
w=0;
#int_timer1
void TIMER1_isr()
disable_interrupts(int_TIMER1);
packet=1;
index_485_rx =0;
#int_rda
void rs485_isr ()
{ x = fgetc(rs_485);
if(!packet)
{ buffer_485_rx[index_485_rx] = x;
if(++index_485_rx == buffer_485_rx)
index_485_rx =0;
set_timer1(46528);//->> 65536-((16.5*XTAL_FREQ)/BAUDRATE)
clear_interrupt(int_TIMER1);
enable_interrupts(int_TIMER1);
///////////////////////"Main_Function"////////////////////////////////////////////
void main ()
index_gp20 = 0;
//init_tx_buffer ();
packet=0;
index_485_rx=0;
index_gp20=0;
w=0;
setup_vref(FALSE);
setup_timer_0(T0_INTERNAL|T0_DIV_256);
//setup_timer_2 ( T2_DIV_BY_4, 0xc0, 2);
enable_interrupts(INT_EXT_L2H );
enable_interrupts(int_rda);
enable_interrupts(global);
port_b_pullups (TRUE);
delay_ms (150);
clr_gp20_buffer();
get_address ();
fprintf (rs_485,"address:%d",address);
output_low (r_led);
output_low (g_led);
while (TRUE){
if (get_packet())
switch (buffer_485_rx [2])
case 0x22: {
fprintf (rs_485,"state_1");
case 0x33 :{
clr_gp20_buffer ();
case 0x55 :{
if (check_gp20_buff ())
send_packet();
}else fputc (err,rs_485);
Posted: Sun Sep 05, 2010 3:14 am |
#int_rda
void rs485_isr ()
x = fgetc(rs_485);
if(!packet)
index_485_rx =0;
This whole thing you're doing here is a mistake. Avoid doing address
tricks. They're unnecessary, and they're left-over from hacker days as
an ASM programmer. When you go to C, all that stuff should be left
behind.
Look at the CCS example file, Ex_sisr.c. It shows how to do an circular
buffer in #int_rda. Here's the file location:
Quote: |
c:\program files\picc\examples\ex_sisr.c |
Posted: Sun Sep 05, 2010 3:23 am |
Also, add #device *=16. This way your processor can use the whole address range of the 628, rather than being stuck with just the low page.
kmp84
Posted: Tue Sep 07, 2010 6:54 am |
PCM programmer wrote: | Quote: |
#int_rda
void rs485_isr ()
x = fgetc(rs_485);
if(!packet)
index_485_rx =0;
behind.
Thanks PCM ..!
My mistake was little stupid, but now I corrected, and project work well.
correction:
Code: | if(++index_485_rx == buffer_size_485_rx)
index_485_rx =0;
