pre assign value to bit in a struct
mds
PostPosted: Tue Sep 07, 2010 6:03 pm     Reply with quote
Hi all,
Can you pre assign a value to a bit inside a struct at compile time?
I often pre assign my vars with values when defining them
such as
int8 fred=0;
Id like to do something similar with the struct byte.
struct dbg_typ{
unsigned fspr     :7;      ///<Spare
unsigned f_rep_en :1;  ///<Enable report printing
}dbgrep;
Id like to set f_rep_en to be true on start up.
Obviously at some startup config section in my code I could simply say
dbgrep=0x80;
But I thought it would be neater, and less chance of being forgotten if I did it at the same point the struct is defined.
PostPosted: Tue Sep 07, 2010 8:08 pm     Reply with quote
The demo program below shows how to initialize a structure in C.
The output of the program is:
fspr = 2a, f_rep_en = 01
#include <18F452.h>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
struct dbg_typ{
unsigned fspr     :7;
}dbgrep = {0x2A, 1};
printf("fspr = %x, f_rep_en = %x \r", dbgrep.fspr, dbgrep.f_rep_en);
mds
PostPosted: Tue Sep 07, 2010 9:01 pm     Reply with quote
haahh many thanks sir.
