mds
pre assign value to bit in a struct |
Posted: Tue Sep 07, 2010 6:03 pm |
Hi all,
Can you pre assign a value to a bit inside a struct at compile time?
I often pre assign my vars with values when defining them
such as
Id like to do something similar with the struct byte.
struct dbg_typ{
unsigned fspr :7; ///<Spare
unsigned f_rep_en :1; ///<Enable report printing
}dbgrep;
Id like to set f_rep_en to be true on start up.
Obviously at some startup config section in my code I could simply say
But I thought it would be neater, and less chance of being forgotten if I did it at the same point the struct is defined. |
Posted: Tue Sep 07, 2010 8:08 pm |
The demo program below shows how to initialize a structure in C.
The output of the program is:
Quote: |
fspr = 2a, f_rep_en = 01
#include <18F452.h>
struct dbg_typ{
unsigned fspr :7;
}dbgrep = {0x2A, 1};
printf("fspr = %x, f_rep_en = %x \r", dbgrep.fspr, dbgrep.f_rep_en);
mds
Posted: Tue Sep 07, 2010 9:01 pm |
haahh many thanks sir. |
