pk178
| Help me with dsPIC |
Posted: Tue Jul 13, 2010 6:23 am |
Hi everybody !
I'm new in dsPIC, I wrote a program, very simple, this is my code :
| Code: | #include <30F2020.h>
#device *=16
#FUSES NOPROTECT, NOWDT, FRC
#use fast_io(d)
void main(){
set_tris_d(0);
setup_oscillator(OSC_RC);
output_d(0);
I want set port D at low logic, but I when I tested, logic level of port is not high, I don't know where is problem, please help me, thank a lot ! |
bkamen
Joined: 07 Jan 2004 Posts: 1616 Location: Central Illinois, USA
Posted: Wed Jul 14, 2010 11:35 am |
Where's the code for the function output_d(0);??
Post your full code (if it's short) or a test program (which that seems to not be) with your compiler version.
I think you need a #use delay (clock=<freq>) declaration.
Also, I think the setup_oscillator is redundant since you have a #FUSE to set the INTRC
pmuldoon
Joined: 26 Sep 2003 Posts: 218 Location: Northern Indiana
Posted: Thu Jul 15, 2010 12:21 pm |
What I see is:
Set all Port D pins to outputs;
Clear all Port D pins (logic low);
Wait forever;
And you say that you set port D low and when testing the port it is not high.
I don't see the problem. |
bkamen
Posted: Thu Jul 15, 2010 12:25 pm |
| pmuldoon wrote: | What I see is:
Wait forever;
I don't either. (reviewing that output_d() is a CCS command I never use)...
Your code does exactly what you describe.
PORT D (all of it) has been set to 0.
