Help me with dsPIC
pk178
Help me with dsPIC
PostPosted: Tue Jul 13, 2010 6:23 am     Reply with quote
Hi everybody !
I'm new in dsPIC, I wrote a program, very simple, this is my code :
#include <30F2020.h>
#device *=16
#FUSES NOPROTECT, NOWDT, FRC
#use fast_io(d)
void main(){
   set_tris_d(0);
   setup_oscillator(OSC_RC);
   output_d(0);
I want set port D at low logic, but I when I tested, logic level of port is not high, I don't know where is problem, please help me, thank a lot !
bkamen
PostPosted: Wed Jul 14, 2010 11:35 am     Reply with quote
Where's the code for the function output_d(0);??
Post your full code (if it's short) or a test program (which that seems to not be) with your compiler version.
I think you need a #use delay (clock=<freq>) declaration.
Also, I think the setup_oscillator is redundant since you have a #FUSE to set the INTRC
-Ben
pmuldoon
PostPosted: Thu Jul 15, 2010 12:21 pm     Reply with quote
What I see is:
Set all Port D pins to outputs;
Clear all Port D pins (logic low);
Wait forever;
And you say that you set port D low and when testing the port it is not high.
I don't see the problem.
bkamen
PostPosted: Thu Jul 15, 2010 12:25 pm     Reply with quote
pmuldoon wrote:
What I see is:
Wait forever;
I don't either. (reviewing that output_d() is a CCS command I never use)...
Your code does exactly what you describe.
PORT D (all of it) has been set to 0.
-Ben
