becool123
xbee radio communication between PICs |
Posted: Mon Jul 12, 2010 4:23 am |
I m trying to send the temperature from one PIC to an other and I am facing some problems.
I work in simulation mode, Proteus 7 for the schematic and CCS C for the C Code.
Here My Code,
the file UART.c
char RecUART (void);
void EmitUART(char c);
void InitUART(void);
/* Initialisation de l'UART */
void InitUART(void)
TXSTA = 0x20;
RCSTA = 0x90;
SPBRG = 0x06;
/* Emission d'un octet sur l'UART */
TXREG = c;
/* Reception d'un Octet sur l'UART */
char RecUART (void)
return(RCREG);
The file xbee.c
#include "USART.c"
void InitXbee(void)
set_tris_d=0x18;
PORTD=0x05;
void SendByte(char c)
EmitUART(c);
char ReadByte(void)
return(RecUART());
void SendString(const unsigned char *s)
int i=0;
while(s[i]!='\0')
/* utilisation de lcd_putch */
SendByte(s[i]);DelayMs(100);
i++;
void ReadString(const unsigned char *s)
int i=0;
while( ReadByte()!='\0')
s[i]=ReadByte()
i++;
DelayMs(100);
Emitters code
#include <16F877.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include "Lcd.c"
#include "USART.c"
#device adc= 10 //sur 10 bits
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7)
#byte PortA = 5 // adresse du PORT A
#byte PortB = 6 // adresse du PORT B
long tension;
float val;
char ordre[32];
setup_timer_1(T1_DISABLED);
set_tris_a(0b00001111);
setup_adc_ports(A_ANALOG);
setup_adc(ADC_CLOCK_DIV_32);
set_adc_channel(0);
InitUART();
InitXbee();
tension = read_adc();
temp=((float)tension/1023)*5*100;
sprintf(ordre,"%f",temp)//pour convertir de float à string
SendString(ordre);
receiver code
#include <16F877.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#fuses HS, NOWDT, NOPROTECT, PUT, NOLVP
#use rs232 (baud = 9600, xmit = PIN_C6, rcv = PIN_C7)
#include "Lcd.c"
#include "Lcd.c"
#include "USART.c"
char ordre[32];
lcd_init();
InitUART();
InitXbee();
while(1 ){
ReadString(ordre);
printf(lcd_putc,"\f%f C",ordre);
Thank you for your future response. |
nina
xbee |
Posted: Mon Jul 12, 2010 9:35 am |
becool123
where did you get xbee.c ?
tks
nina |
Posted: Mon Jul 12, 2010 9:38 am |
Quote: | and I am facing some problems. | It helps if you describe what your problem is. Here we are not good in reading minds (yet).
Code: | #include "Lcd.c"
#include "Lcd.c" | 1 time is enough.
Code: | void InitUART(void)
TXSTA = 0x20;
RCSTA = 0x90;
SPBRG = 0x06;
} | This will overwrite the settings from the '#use RS232' line. Delete these lines.
Code: | /* Emission d'un octet sur l'UART */
TXREG = c;
char RecUART (void)
return(RCREG);
} | Why not use putc() and getc()? These are more portable and CCS has included some code to handle error flags in the UART.
Code: | #use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7) | Add 'ERRORS'. This makes the CCS compiler insert code for clearing error flags in the UART.
Code: | void ReadString(const unsigned char *s)
int i=0;
s[i]=ReadByte()
i++;
DelayMs(100);
} | Why the 100ms delay? Characters will arrive at 19200bps ~ 1920 characters / second ~ 0.5ms per character.
The hardware UART has a receive buffer for 3 characters. When receiving more data the UART will stop and only start again when the error status is cleared (that's why I like the CCS functions!).
Remove this delay, and many of the other delays as well. |
becool123
Posted: Mon Jul 12, 2010 11:10 am |
thank you really for your response
I corrected some lines in my code thanks to your comments, and you have reason about "USART.c", we can use putc(), puts(), getc() , gets() .
So the problem is in Xbee.c :
In the datasheet of xbee, they talk about AT command, RTS, CTS!!!
Should I use them or I can send I receive like I did?
Thank you |
