xbee radio communication between PICs
becool123
PostPosted: Mon Jul 12, 2010 4:23 am     Reply with quote
I m trying to send the temperature from one PIC to an other and I am facing some problems.
I work in simulation mode, Proteus 7 for the schematic and CCS C for the C Code.
Here My Code,
the file UART.c
char RecUART (void);
void EmitUART(char c);
void InitUART(void);
/* Initialisation de l'UART */
void InitUART(void)
TXSTA = 0x20;
RCSTA = 0x90;
SPBRG = 0x06;
/* Emission d'un octet sur l'UART */
TXREG = c;
/* Reception d'un Octet sur l'UART */
char RecUART (void)
return(RCREG);
The file xbee.c
#include "USART.c"
void InitXbee(void)
set_tris_d=0x18;
PORTD=0x05;
void SendByte(char c)
EmitUART(c);
char ReadByte(void)
return(RecUART());
void SendString(const unsigned char *s)
int i=0;
while(s[i]!='\0')
/* utilisation de lcd_putch */
SendByte(s[i]);DelayMs(100);
i++;
void ReadString(const unsigned char *s)
int i=0;
while( ReadByte()!='\0')
s[i]=ReadByte()
i++;
DelayMs(100);
Emitters code
#include <16F877.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include "Lcd.c"
#include "USART.c"
#device adc= 10 //sur 10 bits
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7)
#byte PortA = 5 // adresse du PORT A
#byte PortB = 6 // adresse du PORT B
long tension;
float val;
char ordre[32];
void main() {
setup_timer_1(T1_DISABLED);
set_tris_a(0b00001111);
setup_adc_ports(A_ANALOG);
setup_adc(ADC_CLOCK_DIV_32);
set_adc_channel(0);
InitUART();
InitXbee();
tension = read_adc();
temp=((float)tension/1023)*5*100;
sprintf(ordre,"%f",temp)//pour convertir de float à string
SendString(ordre);
receiver code
#include <16F877.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#fuses HS, NOWDT, NOPROTECT, PUT, NOLVP
#use rs232 (baud = 9600, xmit = PIN_C6, rcv = PIN_C7)
#include "Lcd.c"
#include "Lcd.c"
#include "USART.c"
char ordre[32];
InitUART();
InitXbee();
while(1 ){
ReadString(ordre);
printf(lcd_putc,"\f%f C",ordre);
Thank you for your future response.
nina
xbee
PostPosted: Mon Jul 12, 2010 9:35 am     Reply with quote
becool123
where did you get xbee.c ?
tks
nina
PostPosted: Mon Jul 12, 2010 9:38 am     Reply with quote
It helps if you describe what your problem is. Here we are not good in reading minds (yet).
#include "Lcd.c"
#include "Lcd.c"
1 time is enough.
void InitUART(void)
TXSTA = 0x20;
RCSTA = 0x90;
SPBRG = 0x06;
This will overwrite the settings from the '#use RS232' line. Delete these lines.
TXREG = c;
char RecUART (void)
return(RCREG);
Why not use putc() and getc()? These are more portable and CCS has included some code to handle error flags in the UART.
Add 'ERRORS'. This makes the CCS compiler insert code for clearing error flags in the UART.
int i=0;
s[i]=ReadByte()
i++;
DelayMs(100);
Why the 100ms delay? Characters will arrive at 19200bps ~ 1920 characters / second ~ 0.5ms per character.
The hardware UART has a receive buffer for 3 characters. When receiving more data the UART will stop and only start again when the error status is cleared (that's why I like the CCS functions!).
Remove this delay, and many of the other delays as well.
becool123
PostPosted: Mon Jul 12, 2010 11:10 am     Reply with quote
thank you really for your response Smile
I corrected some lines in my code thanks to your comments, and you have reason about "USART.c", we can use putc(), puts(), getc() , gets() .
So the problem is in Xbee.c :
In the datasheet of xbee, they talk about AT command, RTS, CTS!!!
Should I use them or I can send I receive like I did?
Thank you
