Antony77
PWM not work on 12f683 |
Posted: Sat Jul 17, 2010 3:33 am |
Hi I wrote this code to generate a frequency of 1MHz with a 12f683 using an external 20MHz quartz ... why not working? here's the code:
Code: | #include <12F683.h>
#device adc=8
setup_adc(ADC_CLOCK_DIV_2);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,3,1);
setup_ccp1(CCP_PWM);
set_pwm1_duty(0);
setup_comparator(NC_NC);
setup_vref(FALSE);
while (1)
delay_cycles(1);
Posted: Sat Jul 17, 2010 6:18 am |
setup_timer_2(T2_DIV_BY_1,4,1); //Gives clock/(4*5)
Set_pwm1_duty(10L); //Need the 'L' to give 10 counts of the master clock
At the moment, you have no 'on' period, so no output.... |
Antony77
Posted: Sat Jul 17, 2010 6:21 am |
Oh I forgot to set the duty at 50%...What value should I use for 50%?
Why L? and why "setup_timer_2(T2_DIV_BY_1,4,1); //Gives clock/(4*5)" ? |
