PWM not work on 12f683
Antony77
PostPosted: Sat Jul 17, 2010 3:33 am     Reply with quote
Hi I wrote this code to generate a frequency of 1MHz with a 12f683 using an external 20MHz quartz ... why not working? here's the code:
#include <12F683.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES FCMEN                    //Fail-safe clock monitor enabled
   setup_adc(ADC_CLOCK_DIV_2);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_1,3,1);
   setup_ccp1(CCP_PWM);
   set_pwm1_duty(0);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
while (1)
            delay_cycles(1);
PostPosted: Sat Jul 17, 2010 6:18 am     Reply with quote
setup_timer_2(T2_DIV_BY_1,4,1); //Gives clock/(4*5)
Set_pwm1_duty(10L); //Need the 'L' to give 10 counts of the master clock
At the moment, you have no 'on' period, so no output....
Antony77
PostPosted: Sat Jul 17, 2010 6:21 am     Reply with quote
Oh I forgot to set the duty at 50%...What value should I use for 50%?
Why L? and why "setup_timer_2(T2_DIV_BY_1,4,1); //Gives clock/(4*5)" ?
