christian.koji
Pic16f876A e LCD |
Posted: Fri Jun 11, 2010 6:42 am |
Hey Guys i'm with a problem using LCD with pic16f876A. I cant make it works. I'm using LCD.c from CCS library and the LCD is connected like this:
PIC - LCD
rb2 - db4
rb3 - db5
rb4 - db6
rb5 - db7
Port b2 from pic connected on port db4 in LCD, Port b3 from in Pic connected in port db5(LCD) and so on...
here is the LCD.c note that i've defined ports acording to my connections
LCD.c
//// LCD.C ////
//// Driver for common LCD modules ////
//// lcd_init() Must be called before any other function. ////
//// lcd_putc(c) Will display c on the next position of the LCD. ////
//// The following have special meaning: ////
//// \f Clear display ////
//// \n Go to start of second line ////
//// \b Move back one position ////
//// lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1) ////
//// lcd_getc(x,y) Returns character at position x,y on LCD ////
//// CONFIGURATION ////
//// The LCD can be configured in one of two ways: a.) port access or ////
//// b.) pin access. Port access requires the entire 7 bit interface ////
//// connected to one GPIO port, and the data bits (D4:D7 of the LCD) ////
//// connected to sequential pins on the GPIO. Pin access ////
//// has no requirements, all 7 bits of the control interface can ////
//// can be connected to any GPIO using several ports. ////
//// To use port access, #define LCD_DATA_PORT to the SFR location of ////
//// of the GPIO port that holds the interface, -AND- edit LCD_PIN_MAP ////
//// of this file to configure the pin order. If you are using a ////
//// baseline PIC (PCB), then LCD_OUTPUT_MAP and LCD_INPUT_MAP also must ////
//// be defined. ////
//// Example of port access: ////
//// #define LCD_DATA_PORT getenv("SFR:PORTD") ////
//// To use pin access, the following pins must be defined: ////
//// LCD_ENABLE_PIN ////
//// LCD_RS_PIN ////
//// LCD_RW_PIN ////
//// LCD_DATA4 ////
//// LCD_DATA5 ////
//// LCD_DATA6 ////
//// LCD_DATA7 ////
//// Example of pin access: ////
//// #define LCD_ENABLE_PIN PIN_E0 ////
//// #define LCD_RS_PIN PIN_E1 ////
//// #define LCD_RW_PIN PIN_E2 ////
//// #define LCD_DATA4 PIN_D4 ////
//// #define LCD_DATA5 PIN_D5 ////
//// #define LCD_DATA6 PIN_D6 ////
//// #define LCD_DATA7 PIN_D7 ////
//// (C) Copyright 1996,2009 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
#define LCD_ENABLE_PIN PIN_B0
#define LCD_RS_PIN PIN_B1
#define LCD_DATA4 PIN_B2
#define LCD_DATA5 PIN_B3
#define LCD_DATA6 PIN_B4
#define LCD_DATA7 PIN_B5
// define the pinout.
// only required if port access is being used.
typedef struct
{ // This structure is overlayed
BOOLEAN enable; // on to an I/O port to gain
BOOLEAN rs; // access to the LCD pins.
BOOLEAN rw; // The bits are allocated from
BOOLEAN unused; // low order up. ENABLE will
int data : 4; // be LSB pin of that port.
#if defined(__PCD__) // The port used will be LCD_DATA_PORT.
int reserved: 8;
} LCD_PIN_MAP;
// this is to improve compatability with previous LCD drivers that accepted
// a define labeled 'use_portb_lcd' that configured the LCD onto port B.
#if ((defined(use_portb_lcd)) && (use_portb_lcd==TRUE))
#define LCD_DATA_PORT getenv("SFR:PORTB")
#if defined(__PCB__)
// these definitions only need to be modified for baseline PICs.
// all other PICs use LCD_PIN_MAP or individual LCD_xxx pin definitions.
/* EN, RS, RW, UNUSED, DATA */
const LCD_PIN_MAP LCD_OUTPUT_MAP = {0, 0, 0, 0, 0};
const LCD_PIN_MAP LCD_INPUT_MAP = {0, 0, 0, 0, 0xF};
////////////////////// END CONFIGURATION ///////////////////////////////////
#ifndef LCD_ENABLE_PIN
#define lcd_output_enable(x) lcdlat.enable=x
#define lcd_enable_tris() lcdtris.enable=0
#else
#define lcd_output_enable(x) output_bit(LCD_ENABLE_PIN, x)
#define lcd_enable_tris() output_drive(LCD_ENABLE_PIN)
#ifndef LCD_RS_PIN
#define lcd_output_rs(x) lcdlat.rs=x
#define lcd_rs_tris() lcdtris.rs=0
#else
#define lcd_output_rs(x) output_bit(LCD_RS_PIN, x)
#define lcd_rs_tris() output_drive(LCD_RS_PIN)
#ifndef LCD_RW_PIN
#define lcd_output_rw(x) lcdlat.rw=x
#define lcd_rw_tris() lcdtris.rw=0
#else
#define lcd_output_rw(x) output_bit(LCD_RW_PIN, x)
#define lcd_rw_tris() output_drive(LCD_RW_PIN)
// original version of this library incorrectly labeled LCD_DATA0 as LCD_DATA4,
// LCD_DATA1 as LCD_DATA5, and so on. this block of code makes the driver
// compatible with any code written for the original library
#if (defined(LCD_DATA0) && defined(LCD_DATA1) && defined(LCD_DATA2) && defined(LCD_DATA3) && !defined(LCD_DATA4) && !defined(LCD_DATA5) && !defined(LCD_DATA6) && !defined(LCD_DATA7))
#define LCD_DATA4 LCD_DATA0
#define LCD_DATA5 LCD_DATA1
#define LCD_DATA6 LCD_DATA2
#define LCD_DATA7 LCD_DATA3
#ifndef LCD_DATA4
#ifndef LCD_DATA_PORT
#define LCD_DATA_PORT 0x06 //portb
#define set_tris_lcd(x) set_tris_b(x)
#else
#if defined(PIN_D0)
#define LCD_DATA_PORT getenv("SFR:PORTD") //portd
#else
#define LCD_DATA_PORT getenv("SFR:PORTB") //portb
LCD_PIN_MAP lcd, lcdlat;
#byte lcd = LCD_DATA_PORT
#byte lcdlat = LCD_DATA_PORT
#elif defined(__PCM__)
LCD_PIN_MAP lcd, lcdlat, lcdtris;
#byte lcdtris = LCD_DATA_PORT+0x80
#elif defined(__PCH__)
#byte lcdlat = LCD_DATA_PORT+9
#byte lcdtris = LCD_DATA_PORT+0x12
#elif defined(__PCD__)
#word lcd = LCD_DATA_PORT
#word lcdlat = LCD_DATA_PORT+2
#word lcdtris = LCD_DATA_PORT-0x02
#endif //LCD_DATA4 not defined
#ifndef LCD_TYPE
#define LCD_TYPE 2 // 0=5x7, 1=5x10, 2=2 lines
#ifndef LCD_LINE_TWO
#define LCD_LINE_TWO 0x40 // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (LCD_TYPE << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD
// to start it up.
BYTE lcd_read_nibble(void);
BYTE lcd_read_byte(void)
BYTE low,high;
set_tris_lcd(LCD_INPUT_MAP);
#else
#if (defined(LCD_DATA4) && defined(LCD_DATA5) && defined(LCD_DATA6) && defined(LCD_DATA7))
output_float(LCD_DATA4);
output_float(LCD_DATA5);
output_float(LCD_DATA6);
output_float(LCD_DATA7);
#else
lcdtris.data = 0xF;
lcd_output_rw(1);
delay_cycles(1);
lcd_output_enable(1);
delay_cycles(1);
high = lcd_read_nibble();
lcd_output_enable(0);
delay_cycles(1);
delay_us(1);
low = lcd_read_nibble();
#else
output_drive(LCD_DATA4);
output_drive(LCD_DATA5);
output_drive(LCD_DATA6);
output_drive(LCD_DATA7);
#else
lcdtris.data = 0x0;
return( (high<<4) | low);
BYTE n = 0x00;
/* Read the data port */
n |= input(LCD_DATA4);
n |= input(LCD_DATA5) << 1;
n |= input(LCD_DATA6) << 2;
n |= input(LCD_DATA7) << 3;
return(n);
#else
return(lcd.data);
void lcd_send_nibble(BYTE n)
/* Write to the data port */
output_bit(LCD_DATA4, bit_test(n, 0));
output_bit(LCD_DATA5, bit_test(n, 1));
output_bit(LCD_DATA6, bit_test(n, 2));
output_bit(LCD_DATA7, bit_test(n, 3));
#else
lcdlat.data = n;
delay_cycles(1);
delay_us(2);
void lcd_send_byte(BYTE address, BYTE n)
lcd_output_rs(0);
while ( bit_test(lcd_read_byte(),7) ) ;
lcd_output_rs(address);
delay_cycles(1);
lcd_output_rw(0);
delay_cycles(1);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
BYTE i;
set_tris_lcd(LCD_OUTPUT_MAP);
#else
#else
lcdtris.data = 0x0;
lcd_enable_tris();
lcd_rs_tris();
lcd_rw_tris();
lcd_output_rs(0);
lcd_output_rw(0);
delay_ms(15);
for(i=1;i<=3;++i)
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy(BYTE x, BYTE y)
BYTE address;
if(y!=1)
address=LCD_LINE_TWO;
address=0;
address+=x-1;
lcd_send_byte(0,0x80|address);
void lcd_putc(char c)
switch (c)
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
char lcd_getc(BYTE x, BYTE y)
char value;
lcd_gotoxy(x,y);
while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
lcd_output_rs(1);
value = lcd_read_byte();
lcd_output_rs(0);
return(value);
I've made a simple test, and it is not working.. =/
can somebody help me?
#include <16F876A.h>
#FUSES HS //
#use delay(clock=8000000)
#include <LCD.c>
lcd_init();
printf(lcd_putc,"\fTestando...");
lcd_putc("b");
Posted: Fri Jun 11, 2010 11:56 am |
In your main program, you need to add the #define statements shown
below. The #defines must be put just above the #include <lcd.c>
statement, as shown below. You didn't say what pins you are using
for the E (Enable), RS, and RW signals to the LCD. You need to fill those
in, as shown in bold below:
Quote: |
#define LCD_ENABLE_PIN PIN_xx
#define LCD_RS_PIN PIN_xx
#define LCD_RW_PIN PIN_xx
#include <lcd.c>
If it doesn't work, then post your CCS compiler version.
Also post a description of your contrast control circuit for the LCD, and
post the voltage on the LCD contrast pin. It should be about 0.4 volts. |
christian.koji
Posted: Tue Jun 15, 2010 5:55 am |
Ok, i've made what you said but its not working yet... =/
actually i'm testing on a development board i've bought, guess there is no problem with the contrast or voltage...
it works when i use a pic18f452 linked as 8 bit but with an 8 bit library |
Posted: Tue Jun 15, 2010 11:10 am |
Quote: | Actually i'm testing on a development board |
What's the manufacturer and model number of your board ?
Post a link to the webpage for the board. |
