Help with setting up analog channel select bits?
orlandoG
PostPosted: Tue Jun 08, 2010 10:30 am     Reply with quote
Hello
How would you set up the analog channel select bits as stated below?
For example I want to use AN0-AN6 and AN11 as analog. AN7-AN10 and AN12 as digital. I am using the 18F4550.
PostPosted: Tue Jun 08, 2010 12:00 pm     Reply with quote
You can't do it with that PIC. The 18F4550 only has pre-configured
combinations of analog pins available for selection. You have to pick
one of the settings shown in this section of the 18F4550.h file:
// Constants used in SETUP_ADC_PORTS() are:
