How would you set up the analog channel select bits as stated below?
For example I want to use AN0-AN6 and AN11 as analog. AN7-AN10 and AN12 as digital. I am using the 18F4550.
Posted: Tue Jun 08, 2010 12:00 pm
You can't do it with that PIC. The 18F4550 only has pre-configured
combinations of analog pins available for selection. You have to pick
one of the settings shown in this section of the 18F4550.h file:
