Electronic oven program not working
ssaguiar
PostPosted: Wed Jun 02, 2010 7:44 pm     Reply with quote
Hi to all.
I am working in the implementation of a firmware for an electronic oven.
It uses the pic16f677.
One big problem is that the circuit has 3 devices attached at each of i/o ports:
1 - seven-segments displays (3).
2 - leds (6).
3 - keys (7).
I just can't find a way to make those devices work together.
I have made the leds and displays work together, but when I added some code for the keys, all results messed up (the display doesn't work
any more and the leds blink at random).
I wish to know if somebody can help me to find a solution for this.
This is the code I have until now:
#include   "header.h"
* DESCRIPTION: RTCC Interrupt
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
#int_rtcc
void Timer0Interrupt ( void )
* DESCRIPTION: ADC Interrupt
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
#int_ad
void adinterrupt (void)
   cstate = STATE_ADREADY;
* DESCRIPTION: Timer 1 Interrupt ISR
* RETURN:      none
* ALGORITHM:   none
* NOTES:       interrupt every 1ms
 #INT_TIMER1
 void TIMER1_isr(void)
   //set_timer1(63536 - get_timer1());      // Restart 1 ms timming
   set_timer1(TMR1RESET);               // Restart 1 ms timming
   if (Timer_1ms++ == 5)               // 200 times per second, for the display
      dispsel++;
      Timer_1ms=0;
      Timer_10ms++;
      cstate = STATE_DISP_SELECT;
      if (Timer_10ms == 200)            // 1 second?
         Timer_10ms = 0;               // Zero 10 mseconds counter
         Timer_1s++;                  // Incrementa contador de segundos (p/ conversao ad)
         if (WAITING == TRUE)
            output_toggle(LED_OK);      // Toggle led on/off
            //temper--;
* DESCRIPTION: Main program
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
   setup_oscillator(OSC_8MHZ);            // Let's work at 8 MHz clock
   SysStart();                        // Start system...
   while (TRUE)                     // Do it forever...
      if (cstate == STATE_DISP_SELECT)   // Time to select next display?
         if (fornoligado == TRUE)      // Just when owen ON
            if (dispsel>2)            // If display to show > 2
               dispsel=0;            // Set first display
            showdigit(dispsel, temper);   // Show temperature read in display
         cstate = STATE_IDDLE;         // Return to iddle state
      if (cstate == STATE_ADREADY)      // Is Temperature AD ready?
         readadc();                  // Temperature read
      if (cstate == STATE_IDDLE)         // Time to rest?
         if (Timer_1s >= 10)            // Every 10 seconds
            Timer_1s = 0;            // Reset our seconds counter
            set_adc_channel   (7);      // Select temperature sensor AD
            read_adc(ADC_START_ONLY);   // Start reading of AD channel
* DESCRIPTION: Init all system's units and variables.
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
void SysStart (void)
   char   counter;
   delay_ms ( 200 );                  // Wait enough time after Vdd rise
   Timer_1ms   = 0;                       // Reset Timer counters
   Timer_100ms = 0;                       //   "     "       "
   Timer_1s    = 0;                       //   "     "       "
   Timer_1m   = 0;                  //   "     "       "
   temper      = TEMPERATURE;
   cstate      = STATE_IDDLE;            // Default state of machine is iddle
   fornoligado   = TRUE;
   key_up      = TRUE;
   key_dwn      = TRUE;
   key_temp   = TRUE;
   key_timer   = FALSE;
   key_onoff   = TRUE;
   key_toaster   = FALSE;
   key_light   = FALSE;
   temporizador= TEMPOR;
   port_a_pullups      (FALSE);
   port_b_pullups      (FALSE);
   set_tris_c         (0b10000010);
   output_high(BUZZER);
   setup_comparator   (NC_NC_NC_NC);
   setup_timer_0      (RTCC_INTERNAL | RTCC_DIV_256 | RTCC_8_BIT);
   setup_timer_1      (T1_INTERNAL | T1_DIV_BY_1);
   setup_adc_ports      (sAN5|sAN9);
   setup_adc         (ADC_CLOCK_DIV_4);
   set_timer1         (TMR1RESET);      // Set 1 ms timming
   enable_interrupts   (INT_TIMER1);      // Enable Timer1 interrupt
   enable_interrupts   (INT_RTCC);        // Enable Timer0 interrupt
   enable_interrupts   (INT_AD);         // Enable A/D interrupt
   enable_interrupts   (GLOBAL);          // Enable all interrupts
* DESCRIPTION: readadc - read and plot adc data.
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
void readadc (void)
   char counter;
   long readadc;
   set_adc_channel ( 6 );                  // Select ad channel 0 (fuel)
   readadc = read_adc();                  // Read it
   temper = (int)((readadc*100)/1024);         // Convert value
* DESCRIPTION: Show one digit on display.
* RETURN:      none
* ALGORITHM:   none
* NOTES:       Digits 0 - 2 (LSB, MSB, HSB)
void showdigit (char digit, char value)
   char huns, tens, ones, toshow;
   huns = value / 100;
   tens = ( value - ( huns * 100 ) ) / 10;
   ones = value - ( ( huns * 100 ) + ( tens * 10 ) );
   set_tris_c(0b10000010);
   output_high   (DISPLAY3_EN);   // Desliga displays
   output_high   (DISPLAY2_EN);   //
   output_high   (DISPLAY1_EN);   //
   output_high(LED_CMN);      // Desliga leds
   //To display leds:
   set_tris_a(0b11001011);
   set_tris_b(0b10001111);
   tmp = (key_up      == TRUE)   ? output_low(LED_KEY_UP):output_high(LED_KEY_UP);
   tmp = (key_dwn      == TRUE)   ? output_low(LED_KEY_DWN):output_high(LED_KEY_DWN);
   tmp = (key_temp      == TRUE)   ? output_low(LED_KEY_TEMP):output_high(LED_KEY_TEMP);
   tmp = (key_timer   == TRUE)   ? output_low(LED_KEY_TIMER):output_high(LED_KEY_TIMER);
   //tmp = (key_onoff   == TRUE)   ? output_low(LED_KEY_ONOFF):output_high(LED_KEY_ONOFF);
   tmp = (key_toaster   == TRUE)   ? output_low(LED_KEY_TOASTER):output_high(LED_KEY_TOASTER);
   tmp = (key_light   == TRUE)   ? output_low(LED_KEY_LIGHT):output_high(LED_KEY_LIGHT);
   output_low(LED_CMN);      // Liga leds
   delay_us(100);
   delay_us(100);
   switch ( digit )
   case 0:
      toshow = digittbl[ones];
   case 1:
      toshow = digittbl[tens];
   case 2:
      toshow = digittbl[huns];
   //To display digits:
   set_tris_b(0b00001111);
   tmp = bit_test (toshow,6) ? output_high(SEG_A):output_low(SEG_A);
   tmp = bit_test (toshow,5) ? output_high(SEG_B):output_low(SEG_B);
   tmp = bit_test (toshow,4) ? output_high(SEG_C):output_low(SEG_C);
   tmp = bit_test (toshow,3) ? output_high(SEG_D):output_low(SEG_D);
   tmp = bit_test (toshow,2) ? output_high(SEG_E):output_low(SEG_E);
   tmp = bit_test (toshow,1) ? output_high(SEG_F):output_low(SEG_F);
   tmp = bit_test (toshow,0) ? output_high(SEG_G):output_low(SEG_G);
   switch (dispsel)
      case 0:
         output_low (PIN_C3);
      case 1:
         if((huns>0) &&(tens>0))output_low (PIN_C4);
      case 2:
         if(huns>0) output_low (PIN_C5);
   //check_keys();
   delay_us(10);
   set_tris_a(0b11111111);
   set_tris_b(0b11111111);
   delay_us(10);
   delay_us(10);
   if (input(KEY_UP)==0)
      if (keyupcnt++ == 20)
         key_up ^= 1;
         temper++;
         keyupcnt=0;
   if (input(KEY_DWN)==0)
      if (keydwncnt++ == 20)
         key_dwn ^= 1;
         temper--;
         keydwncnt=0;
   if (input(KEY_TEMP)==0)
      if (keytempcnt++ == 20)
         key_temp ^= 1;
         keytempcnt=0;
   if (input(KEY_TIMER)==0)
      if (keytimercnt++ == 20)
         key_timer ^= 1;
         keytimercnt=0;
   if (input(KEY_ONOFF)==0)
      if (keyonoffcnt++ == 20)
         key_onoff ^= 1;
         keyonoffcnt=0;
   if (input(KEY_TOASTER)==0)
      if (keytoastercnt++ == 20)
         key_toaster ^= 1;
         keytoastercnt=0;
   if (input(KEY_LIGHT)==0)
      if (keylightcnt++ == 20)
         key_light ^= 1;
         keylightcnt=0;
* DESCRIPTION: Check keys.
* RETURN:      none
* ALGORITHM:   none
* NOTES:
void check_keys (void)
   disable_interrupts   (INT_TIMER1);      // Enable Timer1 interrupt
   set_tris_c(0b10110111);
   output_high (PIN_C3);      // Liga anodo display (para poder ler teclas)
   port_a_pullups      (TRUE);
   port_b_pullups      (TRUE);
         key_up ^= 1;
         temper++;
         keyupcnt=0;
         key_dwn ^= 1;
         temper--;
         keydwncnt=0;
         key_temp ^= 1;
         keytempcnt=0;
         key_timer ^= 1;
         keytimercnt=0;
         key_onoff ^= 1;
         keyonoffcnt=0;
         key_toaster ^= 1;
         keytoastercnt=0;
         key_light ^= 1;
         keylightcnt=0;
This is the header file content:
* DESCRIPTION: General stuff
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
//#include <18F4620.h>
//#include <18F452.h>
//#include <16f877a.h>
#include <16f677.h>
#device ADC=10
#device PASS_STRINGS = IN_RAM
#zero_ram
#case
* DESCRIPTION: Timing stuff (clock and serial)
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
#use delay(clock=8000000)
* DESCRIPTION: Fuses
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
#FUSES NOWDT               // NO Watch Dog Timer
#FUSES INTRC_IO                 // High speed Osc (> 4mhz)
#FUSES NOPROTECT                // Code not protected from reading
#FUSES NOBROWNOUT               // No brownout reset
#FUSES PUT                      // Power Up Timer
#FUSES NOCPD                    // No EE protection
#FUSES NOMCLR                   // Master Clear pin disabled
* DESCRIPTION: Includes
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
#include      <stdlib.h>
* DESCRIPTION: System defines
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
#define  TICKS_BETWEEN_INTERRUPTS      2000
#define  INTERRUPT_OVERHEAD            35
#define  TMR1RESET (0xFFFF-(TICKS_BETWEEN_INTERRUPTS-INTERRUPT_OVERHEAD))
 * Definições gerais
#define      YES            1
#define      NO            0
#define      ON            1
#define      OFF            0
#define      TRUE         1
#define      FALSE         0
#define      PORTA         5
#define      PORTB         6
#define      PORTC         7
 * Definição para o sensor de temperatura
#define      SENSOR_TEMP      PIN_C3
 * Definição para as teclas
#define      KEY_UP         PIN_B7
#define      KEY_DWN         PIN_A2
#define      KEY_TEMP      PIN_A3
#define      KEY_TIMER      PIN_B6
#define      KEY_ONOFF      PIN_B5
#define      KEY_TOASTER      PIN_A5
#define      KEY_LIGHT      PIN_B4
 * Definição para os leds
#define      LED_KEY_UP      PIN_B4
#define      LED_KEY_DWN      PIN_A2
#define      LED_KEY_TEMP   PIN_B5
#define      LED_KEY_TIMER   PIN_B6
#define      LED_KEY_ONOFF   PIN_C6
#define      LED_KEY_TOASTER   PIN_A5
#define      LED_KEY_LIGHT   PIN_B4
 * Definição acionamento dos elementos do display
#define      DISPLAY1_EN      PIN_C5
#define      DISPLAY2_EN      PIN_C4
#define      DISPLAY3_EN      PIN_C3
 * Definição acionamento dos leds
#define      LED_CMN         PIN_C2
 * Definição acionamento segmentos dos displays
#define      SEG_A         PIN_A2
#define      SEG_B         PIN_A5
#define      SEG_C         PIN_B7
#define      SEG_D         PIN_B5
#define      SEG_E         PIN_A4
#define      SEG_F         PIN_B6
#define      SEG_G         PIN_B4
#define      LSD            0
#define      MSD            1
#define      HSD            2
#define      TEMPERATURE      180
#define      TEMPOR         40
#define      WAITING         TRUE
#define      LED_OK          PIN_C6
#define      LED_BUZ          PIN_B6
#define      LED_SYS         PIN_A3
#define      LED_TABLE_LENGTH 20
#define      BUZZER          PIN_C0
//#bit      BUZZER         = PORTC.0
* DESCRIPTION: Define Variables
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
int            Timer_1ms, Timer_10ms, Timer_100ms, Timer_1s, Timer_1m;
char         temper, temporizador, tmp;
char         cstate, dispsel;
char         keyupcnt, keydwncnt, keytempcnt, keytimercnt, keyonoffcnt, keytoastercnt, keylightcnt;
int1         fornoligado, key_up, key_dwn, key_temp, key_timer, key_onoff, key_toaster, key_light;
int1         timeforkeys;
enum
   STATE_IDDLE,
   STATE_LEDS,
   STATE_ADREADY,
   STATE_DISP_SELECT
char const digittbl[10]=
   0b00000001,   //0
   0b01001111,   //1
   0b00010010,   //2
   0b00000110,   //3
   0b01001100,   //4
   0b00100100,   //5
   0b00100000,   //6
   0b00001111,   //7
   0b00000000,   //8
   0b00001100   //9
* DESCRIPTION: Functions Prototypes
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
void         readadc      (void);
void         SysStart   (void);
void         showdigit   (char digit, char value);
void         check_keys   (void);
And, finally, this is the part of the circuit which gives me the crips:
http://www.ssaguiar.com/Esquema.JPG
FvM
PostPosted: Thu Jun 03, 2010 1:36 am     Reply with quote
In my opinion, you should do two things:
- Design a simple and clear scheme by pencil and paper method how the different activities in your program should be scheduled. I don't think, that you need other interrupts than the periodic timer tic.
- Organize the code according to this scheme. Now it's very confuse, e.g. reading keys in the "showdigit()" function.
I don't think, that you should have state dependant code in the main function. Just call all sub tasks periodically. All task functions are required to return after a maximum amount of time, e.g a few ms. Then "simultaneous" execution of all tasks can be assured.
ssaguiar
PostPosted: Thu Jun 03, 2010 8:18 am     Reply with quote
Thanks FvM.
I will try to do the way you are indicating.
The major problem is that the original ciruit is somehow messy.
I think that the manufacturer could have used another processor so the digits, keys and leds didn't have to be spread in porta, portb and portc.
Thanks again.
rnielsen
PostPosted: Thu Jun 03, 2010 8:37 am     Reply with quote
Just one quick thing, set_tris() will do nothing unless #use fast_io is also declared.
Ronald
ssaguiar
PostPosted: Thu Jun 03, 2010 11:30 am     Reply with quote
Hi and thanks for your help.
I made some mods, as indicated by our friends rnielsen and FvM.
I just can't make keys work as expected.
I want to make this:
- if one key is pressed once, increase or decrease the temperature in display.
- if the key is still pressed after 2 seconds, enter the auto-increment state (2 per second).
- also, at this moment, when a key is pressed, the display goes blank untill the key is released
The code, at this moment, is:
#include   "header.h"
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
#int_rtcc
   //Not used, untill now...
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
#int_ad
   adready = TRUE;
* Overflow: 1/((FHz/4)/T1_Divider) = 1/(2000000/1) = 1/2000000 = 0,0000005s=0.5us.
* If timer1 is preloaded with 65535 = Overflow = 0.5us * 65536 = 0,032768 s.
* For an overflow of 1ms:
* 0,001 = 0,0000005 * X
* X = 0,001/0,0000005 => X = 2000
* For an overflow of 1ms, preload Timer1 with: 65536-63536, wich is: 2000.
* Thus:
* f(interrupt)=1/(freq_cpu/4/prescaler/preloadvalue)
* As I want one interrupt at every 1 ms:
* f(interrupt)=1/(8000000/4/1/2000)
* f(interrupt)= 1000 times/second => T(f) = 1/f = 0,001 (1 ms).
* RETURN:      none
* ALGORITHM:   none
 #INT_TIMER1
   if (Timer_1ms++ == 10)               // 10 ms?
      Timer_1ms=0;
      Timer_10ms++;
      if (Timer_10ms == 50)            // 0.5 second?
         if (WAITING == TRUE)         // Only blink if waiting for a command.
         Timer_10ms = 0;
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
      if (fornoligado == TRUE)         // Just when oven ON
         showdigit(temper);            // Show temperature read in display
         showleds();                  // Show leds state
         check_keys();
         if (cooking ==TRUE)            // If cooking
            if (adready == TRUE)
               readadc();            // Temperature read & process
               read_adc(ADC_START_ONLY);// Start reading AD channel
            //showtimer();            // Show timer
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
   char   counter;
   fornoligado   = TRUE;
   key_up      = TRUE;
   key_dwn      = TRUE;
   key_temp   = TRUE;
   key_timer   = FALSE;
   key_onoff   = TRUE;
   key_light   = FALSE;
   #use fast_io(A)
   #use fast_io(B)
   #use fast_io(C)
   set_timer1         (63536 - get_timer1());   // Restart 1 ms timming
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
void readadc (void)
   char counter;
   long readadc;
   set_adc_channel ( 6 );                  // Select ad channel 7
* RETURN:      none
* ALGORITHM:   none
void showdigit (char value)
   huns = value / 100;
   if (dispsel++ >2)         // If display to show > 2
   switch ( dispsel )
      case 0:
      case 1:
      case 2:
   output_high   (DISPLAY3_EN);   // Turn off displays
   output_high(LED_CMN);      // Turn off leds
   switch (dispsel)
      case 0:
      case 1:
         ((huns==0)&&(tens==0)) ? output_high (PIN_C4):output_low(PIN_C4);
      case 2:
         (huns>0) ? output_low (PIN_C5):output_high (PIN_C5);
   delay_us(100);
* RETURN:      none
* ALGORITHM:   none
* NOTES:       none
void showleds(void)
   //To display leds:
   output_low(LED_CMN);      // Leds on
   delay_us(100);            // Wait a little bit...
* RETURN:      none
* ALGORITHM:   none
* NOTES:
   set_tris_a(0b00110100);//   11111111);      // Make keys inputs
   set_tris_b(0b11110000);//   11111111);      //   '   '     '
   //port_a_pullups      (TRUE);
   //port_b_pullups      (TRUE);
   //output_low         (DISPLAY3_EN);   // Turn on one display
      delay_ms(250);
      if (keyupcnt++ == 2)
         key_up ^= 1;
         temper++;
         keyupcnt=0;
      delay_ms(250);
      if (keydwncnt++ == 2)
         key_dwn ^= 1;
         temper--;
         keydwncnt=0;
      delay_ms(250);
      if (keytempcnt++ == 2)
         key_temp ^= 1;
         keytempcnt=0;
      delay_ms(250);
      if (keytimercnt++ == 2)
         key_timer ^= 1;
         keytimercnt=0;
      delay_ms(250);
      if (keyonoffcnt++ == 2)
         key_onoff ^= 1;
         keyonoffcnt=0;
      delay_ms(250);
      if (keytoastercnt++ == 2)
         key_toaster ^= 1;
         keytoastercnt=0;
      delay_ms(250);
      if (keylightcnt++ == 2)
         key_light ^= 1;
         keylightcnt=0;
beep:
   movlw   d'150'
   movwf   lbcnt
bploop   bsf   porta,b_beeper
   Wait   500 Microsec,0
   bcf   porta,b_beeper
   Wait   500 Microsec,0
   decfsz   lbcnt,F
   goto   bploop
   return
beep2:
   movlw   d'150'
   movwf   lbcnt
bploop2   bsf   porta,b_beeper
   Wait   250 Microsec,0
   bcf   porta,b_beeper
   Wait   250 Microsec,0
   decfsz   lbcnt,F
   goto   bploop2
   return
playsnd   bsf   porta,b_beeper
psloop   Wait   500 Microsec,0
   bcf   porta,b_beeper
   Wait   500 Microsec,0
   decfsz   lbcnt,F
   goto   psloop
   return
ssaguiar
PostPosted: Fri Jun 04, 2010 8:48 am     Reply with quote
Nobody?
Please, I need, if possible, that someone just give a clue on a way to make the keys being read.
PostPosted: Fri Jun 04, 2010 2:29 pm     Reply with quote
I posted some push-button code in this thread that allows a button to be
held down and to be detected in that state.
http://www.ccsinfo.com/forum/viewtopic.php?t=42027
ssaguiar
PostPosted: Fri Jun 04, 2010 2:45 pm     Reply with quote
Thank you PCM programmer, I will give a look.
