ssaguiar
| Electronic oven program not working |
Posted: Wed Jun 02, 2010 7:44 pm |
Hi to all.
I am working in the implementation of a firmware for an electronic oven.
It uses the pic16f677.
One big problem is that the circuit has 3 devices attached at each of i/o ports:
1 - seven-segments displays (3).
2 - leds (6).
3 - keys (7).
I just can't find a way to make those devices work together.
I have made the leds and displays work together, but when I added some code for the keys, all results messed up (the display doesn't work
any more and the leds blink at random).
I wish to know if somebody can help me to find a solution for this.
This is the code I have until now:
#include "header.h"
* DESCRIPTION: RTCC Interrupt
* RETURN: none
* ALGORITHM: none
* NOTES: none
#int_rtcc
void Timer0Interrupt ( void )
* DESCRIPTION: ADC Interrupt
* RETURN: none
* ALGORITHM: none
* NOTES: none
#int_ad
void adinterrupt (void)
cstate = STATE_ADREADY;
* DESCRIPTION: Timer 1 Interrupt ISR
* RETURN: none
* ALGORITHM: none
* NOTES: interrupt every 1ms
#INT_TIMER1
void TIMER1_isr(void)
//set_timer1(63536 - get_timer1()); // Restart 1 ms timming
set_timer1(TMR1RESET); // Restart 1 ms timming
if (Timer_1ms++ == 5) // 200 times per second, for the display
dispsel++;
Timer_1ms=0;
Timer_10ms++;
cstate = STATE_DISP_SELECT;
if (Timer_10ms == 200) // 1 second?
Timer_10ms = 0; // Zero 10 mseconds counter
Timer_1s++; // Incrementa contador de segundos (p/ conversao ad)
if (WAITING == TRUE)
output_toggle(LED_OK); // Toggle led on/off
//temper--;
* DESCRIPTION: Main program
* RETURN: none
* ALGORITHM: none
* NOTES: none
setup_oscillator(OSC_8MHZ); // Let's work at 8 MHz clock
SysStart(); // Start system...
while (TRUE) // Do it forever...
if (cstate == STATE_DISP_SELECT) // Time to select next display?
if (fornoligado == TRUE) // Just when owen ON
if (dispsel>2) // If display to show > 2
dispsel=0; // Set first display
showdigit(dispsel, temper); // Show temperature read in display
cstate = STATE_IDDLE; // Return to iddle state
if (cstate == STATE_ADREADY) // Is Temperature AD ready?
readadc(); // Temperature read
if (cstate == STATE_IDDLE) // Time to rest?
if (Timer_1s >= 10) // Every 10 seconds
Timer_1s = 0; // Reset our seconds counter
set_adc_channel (7); // Select temperature sensor AD
read_adc(ADC_START_ONLY); // Start reading of AD channel
* DESCRIPTION: Init all system's units and variables.
* RETURN: none
* ALGORITHM: none
* NOTES: none
void SysStart (void)
char counter;
delay_ms ( 200 ); // Wait enough time after Vdd rise
Timer_1ms = 0; // Reset Timer counters
Timer_100ms = 0; // " " "
Timer_1s = 0; // " " "
Timer_1m = 0; // " " "
temper = TEMPERATURE;
cstate = STATE_IDDLE; // Default state of machine is iddle
fornoligado = TRUE;
key_up = TRUE;
key_dwn = TRUE;
key_temp = TRUE;
key_timer = FALSE;
key_onoff = TRUE;
key_toaster = FALSE;
key_light = FALSE;
temporizador= TEMPOR;
port_a_pullups (FALSE);
port_b_pullups (FALSE);
set_tris_c (0b10000010);
output_high(BUZZER);
setup_comparator (NC_NC_NC_NC);
setup_timer_0 (RTCC_INTERNAL | RTCC_DIV_256 | RTCC_8_BIT);
setup_timer_1 (T1_INTERNAL | T1_DIV_BY_1);
setup_adc_ports (sAN5|sAN9);
setup_adc (ADC_CLOCK_DIV_4);
set_timer1 (TMR1RESET); // Set 1 ms timming
enable_interrupts (INT_TIMER1); // Enable Timer1 interrupt
enable_interrupts (INT_RTCC); // Enable Timer0 interrupt
enable_interrupts (INT_AD); // Enable A/D interrupt
enable_interrupts (GLOBAL); // Enable all interrupts
* DESCRIPTION: readadc - read and plot adc data.
* RETURN: none
* ALGORITHM: none
* NOTES: none
void readadc (void)
char counter;
long readadc;
set_adc_channel ( 6 ); // Select ad channel 0 (fuel)
readadc = read_adc(); // Read it
temper = (int)((readadc*100)/1024); // Convert value
* DESCRIPTION: Show one digit on display.
* RETURN: none
* ALGORITHM: none
* NOTES: Digits 0 - 2 (LSB, MSB, HSB)
void showdigit (char digit, char value)
char huns, tens, ones, toshow;
huns = value / 100;
tens = ( value - ( huns * 100 ) ) / 10;
ones = value - ( ( huns * 100 ) + ( tens * 10 ) );
set_tris_c(0b10000010);
output_high (DISPLAY3_EN); // Desliga displays
output_high (DISPLAY2_EN); //
output_high (DISPLAY1_EN); //
output_high(LED_CMN); // Desliga leds
//To display leds:
set_tris_a(0b11001011);
set_tris_b(0b10001111);
tmp = (key_up == TRUE) ? output_low(LED_KEY_UP):output_high(LED_KEY_UP);
tmp = (key_dwn == TRUE) ? output_low(LED_KEY_DWN):output_high(LED_KEY_DWN);
tmp = (key_temp == TRUE) ? output_low(LED_KEY_TEMP):output_high(LED_KEY_TEMP);
tmp = (key_timer == TRUE) ? output_low(LED_KEY_TIMER):output_high(LED_KEY_TIMER);
//tmp = (key_onoff == TRUE) ? output_low(LED_KEY_ONOFF):output_high(LED_KEY_ONOFF);
tmp = (key_toaster == TRUE) ? output_low(LED_KEY_TOASTER):output_high(LED_KEY_TOASTER);
tmp = (key_light == TRUE) ? output_low(LED_KEY_LIGHT):output_high(LED_KEY_LIGHT);
output_low(LED_CMN); // Liga leds
delay_us(100);
delay_us(100);
switch ( digit )
case 0:
toshow = digittbl[ones];
case 1:
toshow = digittbl[tens];
case 2:
toshow = digittbl[huns];
//To display digits:
set_tris_b(0b00001111);
tmp = bit_test (toshow,6) ? output_high(SEG_A):output_low(SEG_A);
tmp = bit_test (toshow,5) ? output_high(SEG_B):output_low(SEG_B);
tmp = bit_test (toshow,4) ? output_high(SEG_C):output_low(SEG_C);
tmp = bit_test (toshow,3) ? output_high(SEG_D):output_low(SEG_D);
tmp = bit_test (toshow,2) ? output_high(SEG_E):output_low(SEG_E);
tmp = bit_test (toshow,1) ? output_high(SEG_F):output_low(SEG_F);
tmp = bit_test (toshow,0) ? output_high(SEG_G):output_low(SEG_G);
switch (dispsel)
case 0:
output_low (PIN_C3);
case 1:
if((huns>0) &&(tens>0))output_low (PIN_C4);
case 2:
if(huns>0) output_low (PIN_C5);
//check_keys();
delay_us(10);
set_tris_a(0b11111111);
set_tris_b(0b11111111);
delay_us(10);
delay_us(10);
if (input(KEY_UP)==0)
if (keyupcnt++ == 20)
key_up ^= 1;
temper++;
keyupcnt=0;
if (input(KEY_DWN)==0)
if (keydwncnt++ == 20)
key_dwn ^= 1;
temper--;
keydwncnt=0;
if (input(KEY_TEMP)==0)
if (keytempcnt++ == 20)
key_temp ^= 1;
keytempcnt=0;
if (input(KEY_TIMER)==0)
if (keytimercnt++ == 20)
key_timer ^= 1;
keytimercnt=0;
if (input(KEY_ONOFF)==0)
if (keyonoffcnt++ == 20)
key_onoff ^= 1;
keyonoffcnt=0;
if (input(KEY_TOASTER)==0)
if (keytoastercnt++ == 20)
key_toaster ^= 1;
keytoastercnt=0;
if (input(KEY_LIGHT)==0)
if (keylightcnt++ == 20)
key_light ^= 1;
keylightcnt=0;
* DESCRIPTION: Check keys.
* RETURN: none
* ALGORITHM: none
* NOTES:
void check_keys (void)
disable_interrupts (INT_TIMER1); // Enable Timer1 interrupt
set_tris_c(0b10110111);
output_high (PIN_C3); // Liga anodo display (para poder ler teclas)
port_a_pullups (TRUE);
port_b_pullups (TRUE);
key_up ^= 1;
temper++;
keyupcnt=0;
key_dwn ^= 1;
temper--;
keydwncnt=0;
key_temp ^= 1;
keytempcnt=0;
key_timer ^= 1;
keytimercnt=0;
key_onoff ^= 1;
keyonoffcnt=0;
key_toaster ^= 1;
keytoastercnt=0;
key_light ^= 1;
keylightcnt=0;
This is the header file content:
* DESCRIPTION: General stuff
* RETURN: none
* ALGORITHM: none
* NOTES: none
//#include <18F4620.h>
//#include <18F452.h>
//#include <16f877a.h>
#include <16f677.h>
#device ADC=10
#device PASS_STRINGS = IN_RAM
#zero_ram
#case
* DESCRIPTION: Timing stuff (clock and serial)
* RETURN: none
* ALGORITHM: none
* NOTES: none
#use delay(clock=8000000)
* DESCRIPTION: Fuses
* RETURN: none
* ALGORITHM: none
* NOTES: none
#FUSES NOWDT // NO Watch Dog Timer
#FUSES INTRC_IO // High speed Osc (> 4mhz)
#FUSES NOPROTECT // Code not protected from reading
#FUSES NOBROWNOUT // No brownout reset
#FUSES PUT // Power Up Timer
#FUSES NOCPD // No EE protection
#FUSES NOMCLR // Master Clear pin disabled
* DESCRIPTION: Includes
* RETURN: none
* ALGORITHM: none
* NOTES: none
#include <stdlib.h>
* DESCRIPTION: System defines
* RETURN: none
* ALGORITHM: none
* NOTES: none
#define TICKS_BETWEEN_INTERRUPTS 2000
#define INTERRUPT_OVERHEAD 35
#define TMR1RESET (0xFFFF-(TICKS_BETWEEN_INTERRUPTS-INTERRUPT_OVERHEAD))
* Definições gerais
#define YES 1
#define NO 0
#define ON 1
#define OFF 0
#define TRUE 1
#define FALSE 0
#define PORTA 5
#define PORTB 6
#define PORTC 7
* Definição para o sensor de temperatura
#define SENSOR_TEMP PIN_C3
* Definição para as teclas
#define KEY_UP PIN_B7
#define KEY_DWN PIN_A2
#define KEY_TEMP PIN_A3
#define KEY_TIMER PIN_B6
#define KEY_ONOFF PIN_B5
#define KEY_TOASTER PIN_A5
#define KEY_LIGHT PIN_B4
* Definição para os leds
#define LED_KEY_UP PIN_B4
#define LED_KEY_DWN PIN_A2
#define LED_KEY_TEMP PIN_B5
#define LED_KEY_TIMER PIN_B6
#define LED_KEY_ONOFF PIN_C6
#define LED_KEY_TOASTER PIN_A5
#define LED_KEY_LIGHT PIN_B4
* Definição acionamento dos elementos do display
#define DISPLAY1_EN PIN_C5
#define DISPLAY2_EN PIN_C4
#define DISPLAY3_EN PIN_C3
* Definição acionamento dos leds
#define LED_CMN PIN_C2
* Definição acionamento segmentos dos displays
#define SEG_A PIN_A2
#define SEG_B PIN_A5
#define SEG_C PIN_B7
#define SEG_D PIN_B5
#define SEG_E PIN_A4
#define SEG_F PIN_B6
#define SEG_G PIN_B4
#define LSD 0
#define MSD 1
#define HSD 2
#define TEMPERATURE 180
#define TEMPOR 40
#define WAITING TRUE
#define LED_OK PIN_C6
#define LED_BUZ PIN_B6
#define LED_SYS PIN_A3
#define LED_TABLE_LENGTH 20
#define BUZZER PIN_C0
//#bit BUZZER = PORTC.0
* DESCRIPTION: Define Variables
* RETURN: none
* ALGORITHM: none
* NOTES: none
int Timer_1ms, Timer_10ms, Timer_100ms, Timer_1s, Timer_1m;
char temper, temporizador, tmp;
char cstate, dispsel;
char keyupcnt, keydwncnt, keytempcnt, keytimercnt, keyonoffcnt, keytoastercnt, keylightcnt;
int1 fornoligado, key_up, key_dwn, key_temp, key_timer, key_onoff, key_toaster, key_light;
int1 timeforkeys;
enum
STATE_IDDLE,
STATE_LEDS,
STATE_ADREADY,
STATE_DISP_SELECT
char const digittbl[10]=
0b00000001, //0
0b01001111, //1
0b00010010, //2
0b00000110, //3
0b01001100, //4
0b00100100, //5
0b00100000, //6
0b00001111, //7
0b00000000, //8
0b00001100 //9
* DESCRIPTION: Functions Prototypes
* RETURN: none
* ALGORITHM: none
* NOTES: none
void readadc (void);
void SysStart (void);
void showdigit (char digit, char value);
void check_keys (void);
And, finally, this is the part of the circuit which gives me the crips:
http://www.ssaguiar.com/Esquema.JPG |
FvM
Posted: Thu Jun 03, 2010 1:36 am |
In my opinion, you should do two things:
- Design a simple and clear scheme by pencil and paper method how the different activities in your program should be scheduled. I don't think, that you need other interrupts than the periodic timer tic.
- Organize the code according to this scheme. Now it's very confuse, e.g. reading keys in the "showdigit()" function.
I don't think, that you should have state dependant code in the main function. Just call all sub tasks periodically. All task functions are required to return after a maximum amount of time, e.g a few ms. Then "simultaneous" execution of all tasks can be assured. |
ssaguiar
Posted: Thu Jun 03, 2010 8:18 am |
Thanks FvM.
I will try to do the way you are indicating.
The major problem is that the original ciruit is somehow messy.
I think that the manufacturer could have used another processor so the digits, keys and leds didn't have to be spread in porta, portb and portc.
Thanks again. |
rnielsen
Posted: Thu Jun 03, 2010 8:37 am |
Just one quick thing, set_tris() will do nothing unless #use fast_io is also declared.
Ronald |
ssaguiar
Posted: Thu Jun 03, 2010 11:30 am |
Hi and thanks for your help.
I made some mods, as indicated by our friends rnielsen and FvM.
I just can't make keys work as expected.
I want to make this:
- if one key is pressed once, increase or decrease the temperature in display.
- if the key is still pressed after 2 seconds, enter the auto-increment state (2 per second).
- also, at this moment, when a key is pressed, the display goes blank untill the key is released
The code, at this moment, is:
#include "header.h"
* RETURN: none
* ALGORITHM: none
* NOTES: none
#int_rtcc
//Not used, untill now...
* RETURN: none
* ALGORITHM: none
* NOTES: none
#int_ad
adready = TRUE;
* Overflow: 1/((FHz/4)/T1_Divider) = 1/(2000000/1) = 1/2000000 = 0,0000005s=0.5us.
* If timer1 is preloaded with 65535 = Overflow = 0.5us * 65536 = 0,032768 s.
* For an overflow of 1ms:
* 0,001 = 0,0000005 * X
* X = 0,001/0,0000005 => X = 2000
* For an overflow of 1ms, preload Timer1 with: 65536-63536, wich is: 2000.
* Thus:
* f(interrupt)=1/(freq_cpu/4/prescaler/preloadvalue)
* As I want one interrupt at every 1 ms:
* f(interrupt)=1/(8000000/4/1/2000)
* f(interrupt)= 1000 times/second => T(f) = 1/f = 0,001 (1 ms).
* RETURN: none
* ALGORITHM: none
#INT_TIMER1
if (Timer_1ms++ == 10) // 10 ms?
Timer_1ms=0;
Timer_10ms++;
if (Timer_10ms == 50) // 0.5 second?
if (WAITING == TRUE) // Only blink if waiting for a command.
Timer_10ms = 0;
* RETURN: none
* ALGORITHM: none
* NOTES: none
if (fornoligado == TRUE) // Just when oven ON
showdigit(temper); // Show temperature read in display
showleds(); // Show leds state
check_keys();
if (cooking ==TRUE) // If cooking
if (adready == TRUE)
readadc(); // Temperature read & process
read_adc(ADC_START_ONLY);// Start reading AD channel
//showtimer(); // Show timer
* RETURN: none
* ALGORITHM: none
* NOTES: none
char counter;
fornoligado = TRUE;
key_up = TRUE;
key_dwn = TRUE;
key_temp = TRUE;
key_timer = FALSE;
key_onoff = TRUE;
key_light = FALSE;
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
set_timer1 (63536 - get_timer1()); // Restart 1 ms timming
* RETURN: none
* ALGORITHM: none
* NOTES: none
void readadc (void)
char counter;
long readadc;
set_adc_channel ( 6 ); // Select ad channel 7
* RETURN: none
* ALGORITHM: none
void showdigit (char value)
huns = value / 100;
if (dispsel++ >2) // If display to show > 2
switch ( dispsel )
case 0:
case 1:
case 2:
output_high (DISPLAY3_EN); // Turn off displays
output_high(LED_CMN); // Turn off leds
switch (dispsel)
case 0:
case 1:
((huns==0)&&(tens==0)) ? output_high (PIN_C4):output_low(PIN_C4);
case 2:
(huns>0) ? output_low (PIN_C5):output_high (PIN_C5);
delay_us(100);
* RETURN: none
* ALGORITHM: none
* NOTES: none
void showleds(void)
//To display leds:
output_low(LED_CMN); // Leds on
delay_us(100); // Wait a little bit...
* RETURN: none
* ALGORITHM: none
* NOTES:
set_tris_a(0b00110100);// 11111111); // Make keys inputs
set_tris_b(0b11110000);// 11111111); // ' ' '
//port_a_pullups (TRUE);
//port_b_pullups (TRUE);
//output_low (DISPLAY3_EN); // Turn on one display
delay_ms(250);
if (keyupcnt++ == 2)
key_up ^= 1;
temper++;
keyupcnt=0;
delay_ms(250);
if (keydwncnt++ == 2)
key_dwn ^= 1;
temper--;
keydwncnt=0;
delay_ms(250);
if (keytempcnt++ == 2)
key_temp ^= 1;
keytempcnt=0;
delay_ms(250);
if (keytimercnt++ == 2)
key_timer ^= 1;
keytimercnt=0;
delay_ms(250);
if (keyonoffcnt++ == 2)
key_onoff ^= 1;
keyonoffcnt=0;
delay_ms(250);
if (keytoastercnt++ == 2)
key_toaster ^= 1;
keytoastercnt=0;
delay_ms(250);
if (keylightcnt++ == 2)
key_light ^= 1;
keylightcnt=0;
beep:
movlw d'150'
movwf lbcnt
bploop bsf porta,b_beeper
Wait 500 Microsec,0
bcf porta,b_beeper
Wait 500 Microsec,0
decfsz lbcnt,F
goto bploop
return
beep2:
movlw d'150'
movwf lbcnt
bploop2 bsf porta,b_beeper
Wait 250 Microsec,0
bcf porta,b_beeper
Wait 250 Microsec,0
decfsz lbcnt,F
goto bploop2
return
playsnd bsf porta,b_beeper
psloop Wait 500 Microsec,0
bcf porta,b_beeper
Wait 500 Microsec,0
decfsz lbcnt,F
goto psloop
return
ssaguiar
Posted: Fri Jun 04, 2010 8:48 am |
Nobody?
Please, I need, if possible, that someone just give a clue on a way to make the keys being read.
Thanks |
ssaguiar
Posted: Fri Jun 04, 2010 2:45 pm |
| Thank you PCM programmer, I will give a look. |
