VDIP used in FIFO mode
jacqueskleynhans
PostPosted: Tue May 18, 2010 5:40 am     Reply with quote
Hi Guys, Has anyone been able to operate this module in fifo mode.
I have been going around forum after forum, and the info is good i just cant find anything on the fifo mode.
Reagrds
"THE ONLY EASY DAY WAS YESTERDAY"
PostPosted: Tue May 18, 2010 6:24 am     Reply with quote
Using Google I found this:
http://forums.parallax.com/forums/pr.aspx?f=25&m=171953
One thing they mention is a minimum required firmware version. It seems
a few people on that site have experience in FIFO mode, you should try
there. It's a really long thread with a lot of good information.
jacqueskleynhans
PostPosted: Tue May 18, 2010 7:09 am     Reply with quote
I checked it out, before but it seems that post turned into a sd card :( post.
Its actually my issue, because i want to interface it on an fpga and i dant want to use ascii, only binary....
Ill figure it out
thx for the reply though
PostPosted: Tue May 18, 2010 7:18 am     Reply with quote
There are at least two of the posters who have it running in FIFO mode.
Have you sent them a message? I assume you are trying to do this for speed?
jacqueskleynhans
PostPosted: Tue May 18, 2010 11:26 am     Reply with quote
Well I am actually building a camera for a little satellite, The camera has an 8bit data bus which is interface to a 64mb low power sram via the FPGA. The usb side of things is just for temp storage and proof of concept. As I am writing all the interface from scratch and not using previous cores or modules i need a simple proof of concept display ie usb drive >> Pc.
And yes, in fifo mode data rate is the highst.
