Can someone please help me with ISR routine for input change
notification interrupt on PIC24FJ256GB110?
I found the following constants in .h file:
#define INT_CNI 84
#define INTR_CN_PIN 0x8000 // or in a PIN_xx constant
but I don't know how to use them. I want CN interrupt on pin CN79.
How should I define ISR handler routine and how should I call
enable_interrupts(something) function?
Thanks for any help!
pmaechler
Change Notification Interrupt PIC24
Posted: Mon Apr 12, 2010 6:41 pm
Hi
Use following expression to enable the interrupt pin:
