PIC24FJ input change notification interrupt
tomcuga
PostPosted: Fri Mar 05, 2010 1:43 pm     Reply with quote
Can someone please help me with ISR routine for input change
notification interrupt on PIC24FJ256GB110?
I found the following constants in .h file:
#define INT_CNI        84
#define INTR_CN_PIN    0x8000  // or in a PIN_xx constant
but I don't know how to use them. I want CN interrupt on pin CN79.
How should I define ISR handler routine and how should I call
enable_interrupts(something) function?
Thanks for any help!
pmaechler
Change Notification Interrupt PIC24
PostPosted: Mon Apr 12, 2010 6:41 pm     Reply with quote
Hi
Use following expression to enable the interrupt pin:
enable_interrupts(INTR_CN_PIN|Pin_B0);
and define the interrupt routine after #int_cni
that should work...
