Could anyone help me on the code for I2C communication for PIC18F4520 and ADS1113? I just use ADS1113 as an A/D converter and there is no other I2C devices in the design.
I have two 10K pull-up resistors in the design. So I think there is no problem for hardware since I copied the connections in the datasheet of ADS1113. Actually, I followed the instructions for coding in the datasheet of ADS1113, but my code does not work at all. Readings are 65535 all the time. Someone please help me. Thanks.
Posted: Fri Apr 02, 2010 9:50 am
Post your driver code and a test program that calls the driver functions.
Make sure the posted code compiles with no errors. Also post your
compiler version.
