dsPIC33 works when ICD programmed, but not when ICD debugged
soundscu
PostPosted: Thu Dec 03, 2009 10:09 am     Reply with quote
This one has me stumped. I have code that works when programmed into the dsPIC33 with an ICD3. But the same code does not work when trying to debug using the ICD3. The environment is MPLAB 8.40, and CCS PCD Compiler 4.101. (I also have the CCS IDE, but I can't get debugging to work for any project with it.)
I hit RUN, the target is indicated as "Running", nothing happens to indicate it actually is running, then I the message "Target Halted" appears, and the debugger stops.
A simple test program works correctly -- this is not a hardware or setup issue. At one point, it seemed that adding code to a timer interrupt routine was causing the problem -- a short routine that just incremented a counter worked fine, but additional code would not work.
Again, everything compiles fine, and works *perfectly* when programmed (not in debug mode). So my programming would seem to be correct.
Now I'm adding routines and debugging is required, and I can't do it. ARGHHHHH.
Any tips? Help very much appreciated.
Jim
soundscu
PostPosted: Thu Dec 03, 2009 11:48 am     Reply with quote
Even more strange:
I can debug successfully with an ICD2. So the problem seems to rest with the ICD3.
r00x
PostPosted: Fri Mar 19, 2010 7:39 am     Reply with quote
Hi there - did you ever resolve this problem?
I'd love to know how if you have. I'm trying to program a PIC18F4620 via a Pickit 2 and am having the exact same issues: software works fine when programmed, but no chip response followed immediately by "Target Halted" under debug.
When I hit Animate, the Pickit 2 output window spams "Stepping Target - Pickit 2 Ready - Stepping Target - Pickit 2 Ready" but the chip does nothing. Rolling Eyes
