iruraz
PWM-duty cycle problem |
Posted: Wed Mar 17, 2010 8:43 am |
Hi Everybody,
I try to obtain 120KHz carrier signal with 50% duty cycle. My crystal frequency 7.68MHz.
setup_timer_2(t2_div_by_16,0,1);
This part of code give 120KHz signal but I couldn't see 50% duty cycle because PR2=0. How can I obtain 50% duty cycle?
#include <16f877.h>
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use delay (clock=7680000)
#use fast_io(c)
setup_psp(PSP_DISABLED); // PSP birimi devre dışı
setup_spi(SPI_SS_DISABLED); // SPI birimi devre dışı
setup_timer_1(T1_DISABLED); // T1 zamanlayıcısı devre dışı
setup_adc_ports(NO_ANALOGS); // ANALOG giriş yok
setup_adc(ADC_OFF); // ADC birimi devre dışı
set_tris_c(0x00);
setup_ccp1(ccp_pwm);
Regards. |
meereck
Posted: Wed Mar 17, 2010 9:07 am |
according to my calculations:
Code: | setup_timer_2(t2_div_by_1,15,1);
set_pwm1_duty(8); |
iruraz
Posted: Wed Mar 17, 2010 12:10 pm |
Thanks @meereck. I tried and obtained. Product result is same but what is the difference between
Code: | setup_timer_2(t2_div_by_1,15,1); |
and
Code: | setup_timer_2(t2_div_by_16,0,1); |
Ttelmah |
Posted: Wed Mar 17, 2010 4:00 pm |
You are setting the prescaler to 16.
You can't basically divide 'counts' taking place in the prescaler, only ones taking place in the actual PWM counter (thought further note below here...).
The counter in Meerek's version, is counting to 16 and resetting (always PR2+1), so you can then set the duty to half this value to get 50%.
Using the prescaler, the main counter, is just counting 0,1,0,1, so you can either get off, or full on, not a 50% duty cycle...
However, the actual 'counter', is 2 bits longer than the PR2 register. These extra bits would potentially allow a 50% duty cycle, using:
set_pwm_duty(2L);
Using a 'long' value, tells the compiler to access the extra bits. Effectively accessing 1/4 'count' steps.
iruraz
Posted: Thu Mar 18, 2010 2:10 pm |
Thanks @Ttelmah . |
