PWM-duty cycle problem
iruraz
PostPosted: Wed Mar 17, 2010 8:43 am     Reply with quote
Hi Everybody,
I try to obtain 120KHz carrier signal with 50% duty cycle. My crystal frequency 7.68MHz.
setup_timer_2(t2_div_by_16,0,1);
This part of code give 120KHz signal but I couldn't see 50% duty cycle because PR2=0. How can I obtain 50% duty cycle?
#include <16f877.h>
#fuses XT,NOWDT,NOPROTECT,NOBROWNOUT,NOLVP,NOPUT,NOWRT,NODEBUG,NOCPD
#use delay (clock=7680000)
#use fast_io(c)
   setup_psp(PSP_DISABLED);        // PSP birimi devre dışı
   setup_spi(SPI_SS_DISABLED);     // SPI birimi devre dışı
   setup_timer_1(T1_DISABLED);     // T1 zamanlayıcısı devre dışı
   setup_adc_ports(NO_ANALOGS);    // ANALOG giriş yok
   setup_adc(ADC_OFF);             // ADC birimi devre dışı
   set_tris_c(0x00);
   setup_ccp1(ccp_pwm);
Regards.
meereck
PostPosted: Wed Mar 17, 2010 9:07 am     Reply with quote
according to my calculations:
setup_timer_2(t2_div_by_1,15,1);
set_pwm1_duty(8);
iruraz
PostPosted: Wed Mar 17, 2010 12:10 pm     Reply with quote
Thanks @meereck. I tried and obtained. Product result is same but what is the difference between
and
PostPosted: Wed Mar 17, 2010 4:00 pm     Reply with quote
You are setting the prescaler to 16.
You can't basically divide 'counts' taking place in the prescaler, only ones taking place in the actual PWM counter (thought further note below here...).
The counter in Meerek's version, is counting to 16 and resetting (always PR2+1), so you can then set the duty to half this value to get 50%.
Using the prescaler, the main counter, is just counting 0,1,0,1, so you can either get off, or full on, not a 50% duty cycle...
However, the actual 'counter', is 2 bits longer than the PR2 register. These extra bits would potentially allow a 50% duty cycle, using:
set_pwm_duty(2L);
Using a 'long' value, tells the compiler to access the extra bits. Effectively accessing 1/4 'count' steps.
iruraz
PostPosted: Thu Mar 18, 2010 2:10 pm     Reply with quote
Thanks @Ttelmah .
