Oli Guest
Optimising LCD routines. |
Posted: Fri Feb 12, 2010 9:36 am |
Hi All
I'm using a PIC24FJGB110 and a 128x 128 LCD. I have some animation going on the LCD and at the moment, it needs the core running at 32Mhz to be able to achieve the necessary frames per second. It is a battery powered application so any power savings would make a big difference - I am already aware of clock switching but want to optimise my code before taking this path
I have written all of the libraries and know they could run MUCH quicker, but I'm a bit lost on where to start.
The orientation of the display can be changed in the program, so I have performed transforms on each pixel before writing it to the buffer.
Firstly, the buffer is:
Code: | int8 glcd_buffer[GLCD_BYTES]; |
and
Code: | #define GLCD_WIDTH 128
#define GLCD_HEIGHT 128
#define GLCD_ROWS (LCD_HEIGHT/8)
#define GLCD_BYTES 2048 // 128 x 128 / 8; |
So to write a pixel to the buffer:
Code: | void glcd_pixel(int8 x, int8 y, int8 colour)
int8* p;
int8 position_temp; // temporarily stores
int16 temp;
if ((x >= GLCD_WIDTH) || (x < 0))
return;
#ifdef ROTATE_GLCD
position_temp = x;
switch (glcd_angle)
case 0: x = y;
y = GLCD_HEIGHT - position_temp - 1; break;
case 90: break;
case 180: x = GLCD_WIDTH - y - 1;
y = position_temp;
case 270: break;
temp = y/8;
temp *= 128;
temp += x;
p = glcd_buffer + temp;
if(colour)
bit_set(*p, y%8);
bit_clear(*p, y%8);
then to write from the buffer to the LCD, I use:
Code: | void glcd_update(void)
int16 i;
glcd_goto_position(0,0);
// Loop through the vertical pages
for(i = 0; i < GLCD_BYTES; i++)
glcd_data_write(glcd_buffer[i]); // Turn pixels on or off
which uses:
Code: | void glcd_data_write(BYTE data)
WRITE_LCD_PORT(data);
output_bit(LCD_CSB, 0);
output_bit(LCD_WR, 0);
output_bit(LCD_WR, 1);
output_bit(LCD_CSB, 1);
which then uses the following Macro:
Code: | #define WRITE_LCD_PORT(x) \
output_bit(LCD_D0, (x & 1)); \
output_bit(LCD_D1, ((x >> 1) & 1)); \
output_bit(LCD_D2, ((x >> 2) & 1)); \
output_bit(LCD_D3, ((x >> 3) & 1)); \
output_bit(LCD_D4, ((x >> 4) & 1)); \
output_bit(LCD_D5, ((x >> 5) & 1)); \
output_bit(LCD_D6, ((x >> 6) & 1)); \
output_bit(LCD_D7, ((x >> 7) & 1)); |
If you have any suggestions to optimise any of the above code, please let me know! (or any other general tips). Immediately, the WRITE_LCD_PORT comes to mind because of the number of bit shifts...but I'm not sure how to change it.
Many thanks in advance |
Posted: Fri Feb 12, 2010 4:18 pm |
When intending optimization, it'a good idea to check, how the compiler treats particular C constructs.
In your WRITE_LCD_PORT(x) macro, each line with a bit shift is converted to not less than 10 machine
instructions by PCD. Code: | output_bit(LCD_D2, ((x >> 2) & 1)); |
Using bit_test() instead reduces the amount by four. Having ordered pins for the LCD interface only consumes two
instructions to write x to the port. So it's clear, what optimization means first - using appropriate hardware connections.
The next point is analysing which lines of code are executed most often and try to make them lightweight. |
