Optimising LCD routines.
Oli
PostPosted: Fri Feb 12, 2010 9:36 am     Reply with quote
Hi All
I'm using a PIC24FJGB110 and a 128x 128 LCD. I have some animation going on the LCD and at the moment, it needs the core running at 32Mhz to be able to achieve the necessary frames per second. It is a battery powered application so any power savings would make a big difference - I am already aware of clock switching but want to optimise my code before taking this path
I have written all of the libraries and know they could run MUCH quicker, but I'm a bit lost on where to start.
The orientation of the display can be changed in the program, so I have performed transforms on each pixel before writing it to the buffer.
Firstly, the buffer is:
int8 glcd_buffer[GLCD_BYTES];
and
#define GLCD_WIDTH    128
#define GLCD_HEIGHT   128
#define GLCD_ROWS     (LCD_HEIGHT/8)
#define GLCD_BYTES    2048    // 128 x 128   /  8;
So to write a pixel to the buffer:
void glcd_pixel(int8 x, int8 y, int8 colour)
   int8* p;
   int8 position_temp;  // temporarily stores
   int16 temp;
   if ((x >= GLCD_WIDTH) || (x < 0))
      return;
   #ifdef ROTATE_GLCD
   position_temp = x;
   switch (glcd_angle)
      case 0:     x = y;
                  y = GLCD_HEIGHT - position_temp - 1; break;
      case 90:    break;
      case 180:   x = GLCD_WIDTH - y - 1;
                  y = position_temp;
      case 270:   break;
   temp =  y/8;
   temp *= 128;
   temp += x;
   p = glcd_buffer + temp;
   if(colour)
      bit_set(*p, y%8);
      bit_clear(*p, y%8);
then to write from the buffer to the LCD, I use:
void glcd_update(void)
   int16 i;
   glcd_goto_position(0,0);
   // Loop through the vertical pages
   for(i = 0; i < GLCD_BYTES; i++)
      glcd_data_write(glcd_buffer[i]);      // Turn pixels on or off
which uses:
 void glcd_data_write(BYTE data)
   WRITE_LCD_PORT(data);
   output_bit(LCD_CSB, 0);
   output_bit(LCD_WR, 0);
   output_bit(LCD_WR, 1);
   output_bit(LCD_CSB, 1);
which then uses the following Macro:
#define WRITE_LCD_PORT(x)    \
output_bit(LCD_D0, (x & 1)); \
output_bit(LCD_D1, ((x >> 1) & 1)); \
output_bit(LCD_D2, ((x >> 2) & 1)); \
output_bit(LCD_D3, ((x >> 3) & 1)); \
output_bit(LCD_D4, ((x >> 4) & 1)); \
output_bit(LCD_D5, ((x >> 5) & 1)); \
output_bit(LCD_D6, ((x >> 6) & 1)); \
output_bit(LCD_D7, ((x >> 7) & 1));
If you have any suggestions to optimise any of the above code, please let me know! (or any other general tips). Immediately, the WRITE_LCD_PORT comes to mind because of the number of bit shifts...but I'm not sure how to change it.
Many thanks in advance
PostPosted: Fri Feb 12, 2010 4:18 pm     Reply with quote
When intending optimization, it'a good idea to check, how the compiler treats particular C constructs.
In your WRITE_LCD_PORT(x) macro, each line with a bit shift is converted to not less than 10 machine
instructions
by PCD.
Using bit_test() instead reduces the amount by four. Having ordered pins for the LCD interface only consumes two
instructions to write x to the port. So it's clear, what optimization means first - using appropriate hardware connections.
The next point is analysing which lines of code are executed most often and try to make them lightweight.
