sindyme
My #int_RDA can't work on PIC24F256GB106 |
Posted: Thu Feb 11, 2010 11:59 pm |
My CCS Verison is 4.104 for "PCDIDE Compiler".
I'm use "PIC24F256GB106" for RS232.
If I no use "#int_RDA" that PIC will be normal work.
But when I use "#int_RDA" function that PIC will unceasing redundant reset.
It will not do main function !
Where is bug at my code ?
These is normal work code.
#include <stdio.h>
#include <string.h>
#pin_select U1TX=PIN_G6
#pin_select U1RX=PIN_G7
#pin_select U2TX=PIN_D8
#pin_select U2RX=PIN_D9
#use rs232(UART1,baud=115200,parity=N,bits=8,stream=coma)
#use rs232(UART2,baud=115200,parity=N,bits=8,stream=comb)
//setup_spi(SPI_MASTER | SPI_MODE_3 |SPI_CLK_DIV_1);
//setup_spi2(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
enable_interrupts(INT_RDA);
enable_interrupts(INT_RDA2);
for(;;)
fprintf(coma,"comb test a ... \r\n");
fprintf(comb,"comb test b ... \r\n");
delay_ms(2000);
If I add #INT_RDA function that PIC will reset again and again
There is bug code.
#include <stdio.h>
#include <string.h>
//One rs232 module setting:
char rs_buff[512],check_str[20],str_temp[20];
int16 buff_number,i,j,k,fund_str_point,temp1,temp2;
//Two rs232 module setting:
char rs_buffb[512],check_strb[20],str_tempb[20];
int16 buff_numberb,ib,jb,kb,fund_str_pointb,temp1b,temp2b;
#int_RDA
void RDA_isr(void)
//clear_interrupt(INT_RDA2);
disable_interrupts(INT_RDA2);
rs_buff[buff_number]=getc(coma);
if(buff_number<512)
buff_number=buff_number+1;
buff_number=0;
#int_RDA2
void RDA2_isr(void)
//clear_interrupt(INT_RDA);
disable_interrupts(INT_RDA);
rs_buffb[buff_numberb]=getc(comb);
if(buff_numberb<512)
buff_numberb=buff_numberb+1;
buff_numberb=0;
//RS232 Buff Cls
void rs232_buff_cls()
for(buff_number=0;buff_number<512;buff_number++)
rs_buff[buff_number]=' ';
buff_number=0; //RS232 Buff Point set to 0
//RS232 Buff Clsb
void rs232_buff_clsb()
for(buff_numberb=0;buff_numberb<512;buff_numberb++)
rs_buffb[buff_numberb]=' ';
buff_numberb=0; //RS232 Buff Point set to 0
//Check string
void string_buff_check(int str_num_check)
temp1=i;
temp2=j;
if(buff_number<str_num_check)
fund_str_point=512; //代表無找到或錯誤
for(i=0;i<(buff_number-str_num_check);i++)
for(j=0;j<20;j++)
str_temp[j]=' ';
for(j=0;j<str_num_check;j++)
str_temp[j]=rs_buff[i+j];
//將RS232 BUFF內的字元與輸入字元比較
if(strncmp(str_temp,check_str,str_num_check)==0)
fund_str_point=i;
i=buff_number+1;
fund_str_point=512;
i=temp1;
j=temp2;
//Check stringb
void string_buff_checkb(int str_num_checkb)
temp1b=ib;
temp2b=jb;
if(buff_numberb<str_num_checkb)
fund_str_pointb=512; //代表無找到或錯誤
for(ib=0;ib<(buff_numberb-str_num_checkb);ib++)
for(jb=0;jb<20;jb++)
str_tempb[jb]=' ';
for(jb=0;jb<str_num_checkb;jb++)
str_tempb[jb]=rs_buffb[ib+jb];
if(strncmp(str_tempb,check_strb,str_num_checkb)==0)
fund_str_pointb=i;
ib=buff_numberb+1;
ib=temp1b;
jb=temp2b;
void Module_Initial()
RE_Module_Initial:
if(Module_ERR==0)
rs232_buff_cls();
fprintf(coma,"AT\r\n"); //check module
delay_ms(200);
strcpy(check_str,"OK");
string_buff_check(2);
if(fund_str_point==512)
fprintf(coma,"AT Command Error...\r\n");
GOTO RE_Module_Initial;
setup_wdt(WDT_OFF);
Module_ERR = 0; GSM_Inlcnt = 0; Msg_ERR = 0; GPRS_ERR = 0;
SISW_ERR = 0;
fprintf(coma,"coma working OK ... \r\n");
fprintf(comb,"comb working OK ... \r\n");
output_high(EEPROM_SELECT); //SPI CS Initial
delay_ms(2000);
Module_Initial(); //<--- First do this
for(;;)
delay_ms(2000);
There is PIC .h file.
#include <24FJ256GB106.h>
#FUSES NOJTAG //JTAG disabled
#FUSES ICSP1 //ICD uses PGC1/PGD1 pins
#FUSES WINDIS //Watch Dog Timer in non-Window mode
#FUSES WPRES128 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16 //Watch Dog Timer PostScalar 1:32768
#FUSES PR //Primary Oscillator
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO //OSC2 is clock output
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES IOL1WAY //Allows only one reconfiguration of peripheral pins
#FUSES WPEND_LOW
#FUSES NOWPCFG
#FUSES NOWPDIS
#FUSES WPFP3
#FUSES WPFP4
#FUSES PLL6 //Divide By 12(48MHz oscillator input)
#FUSES DISUVREG
#FUSES WPFP5
#FUSES WPFP6
#FUSES WPFP0
#FUSES WPFP1
#FUSES WPFP2
#FUSES WPFP7
#FUSES WPFP8
#FUSES RESERVED //Used to set the reserved FUSE bits
#use delay(clock=22118400)
Posted: Fri Feb 12, 2010 2:28 am |
- Interrupt nesting is disabled by default, you don't need to disable or enable any interrupts in the interrupt function.
- You're writing one byte out of bounds of your rx buffers (rs_buffb[512]).
Apart from these points, I don't see problems with your code. RS232 interrupts are generally working with PIC24 chips and recent PCD versions. |
Posted: Fri Feb 12, 2010 4:00 am |
Has the problem with the UART numbers being reversed, been fixed?.
If not, then the code would hang.
I really would suggest, getting just _one_ UART working first.
Posted: Fri Feb 12, 2010 7:20 am |
Quote: | Has the problem with the UART numbers being reversed, been fixed?. |
Yes, if I remember right. But it's a good idea to check correct SFR usage and PIN_SELECT coding anyway. It has
been partially wrong with PIC24FJxxGB1xx in previous compiler versions and is still wrong for some more exotic
PIC24 types. |
sindyme
Posted: Fri Feb 12, 2010 8:34 am |
FvM wrote: | Quote: | Has the problem with the UART numbers being reversed, been fixed?. |
PIC24 types. |
I will continue try. This week is chinese new year , I have seven day's holiday.
Next week I will try again ~ |
