My #int_RDA can't work on PIC24F256GB106
sindyme
PostPosted: Thu Feb 11, 2010 11:59 pm     Reply with quote
My CCS Verison is 4.104 for "PCDIDE Compiler".
I'm use "PIC24F256GB106" for RS232.
If I no use "#int_RDA" that PIC will be normal work.
But when I use "#int_RDA" function that PIC will unceasing redundant reset.
It will not do main function !
Where is bug at my code ?
These is normal work code.
#include <stdio.h>
#include <string.h>
#pin_select U1TX=PIN_G6
#pin_select U1RX=PIN_G7
#pin_select U2TX=PIN_D8
#pin_select U2RX=PIN_D9
#use rs232(UART1,baud=115200,parity=N,bits=8,stream=coma)
#use rs232(UART2,baud=115200,parity=N,bits=8,stream=comb)
   //setup_spi(SPI_MASTER | SPI_MODE_3 |SPI_CLK_DIV_1);
   //setup_spi2(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
   enable_interrupts(INT_RDA);
   enable_interrupts(INT_RDA2);
   for(;;)
          fprintf(coma,"comb test a ... \r\n");
          fprintf(comb,"comb test b ... \r\n");
          delay_ms(2000);
If I add #INT_RDA function that PIC will reset again and again
There is bug code.
#include <stdio.h>
#include <string.h>
//One rs232 module setting:
char rs_buff[512],check_str[20],str_temp[20];
int16 buff_number,i,j,k,fund_str_point,temp1,temp2;
//Two rs232 module setting:
char rs_buffb[512],check_strb[20],str_tempb[20];
int16 buff_numberb,ib,jb,kb,fund_str_pointb,temp1b,temp2b;
#int_RDA
void RDA_isr(void)
   //clear_interrupt(INT_RDA2);
   disable_interrupts(INT_RDA2);
   rs_buff[buff_number]=getc(coma);
   if(buff_number<512)
       buff_number=buff_number+1;
       buff_number=0;
#int_RDA2
void RDA2_isr(void)
   //clear_interrupt(INT_RDA);
   disable_interrupts(INT_RDA);
   rs_buffb[buff_numberb]=getc(comb);
   if(buff_numberb<512)
       buff_numberb=buff_numberb+1;
       buff_numberb=0;
//RS232 Buff Cls
void rs232_buff_cls()
   for(buff_number=0;buff_number<512;buff_number++)
       rs_buff[buff_number]=' ';
       buff_number=0;   //RS232 Buff Point set to 0
//RS232 Buff Clsb
void rs232_buff_clsb()
   for(buff_numberb=0;buff_numberb<512;buff_numberb++)
       rs_buffb[buff_numberb]=' ';
       buff_numberb=0;   //RS232 Buff Point set to 0
//Check string
void string_buff_check(int str_num_check)
    temp1=i;
    temp2=j;
    if(buff_number<str_num_check)
        fund_str_point=512;            //代表無找到或錯誤
       for(i=0;i<(buff_number-str_num_check);i++)
           for(j=0;j<20;j++)
              str_temp[j]=' ';
           for(j=0;j<str_num_check;j++)
               str_temp[j]=rs_buff[i+j];
           //將RS232 BUFF內的字元與輸入字元比較
           if(strncmp(str_temp,check_str,str_num_check)==0)
               fund_str_point=i;
               i=buff_number+1;
               fund_str_point=512;
    i=temp1;
    j=temp2;
//Check stringb
void string_buff_checkb(int str_num_checkb)
    temp1b=ib;
    temp2b=jb;
    if(buff_numberb<str_num_checkb)
        fund_str_pointb=512;            //代表無找到或錯誤
       for(ib=0;ib<(buff_numberb-str_num_checkb);ib++)
           for(jb=0;jb<20;jb++)
              str_tempb[jb]=' ';
           for(jb=0;jb<str_num_checkb;jb++)
               str_tempb[jb]=rs_buffb[ib+jb];
           if(strncmp(str_tempb,check_strb,str_num_checkb)==0)
               fund_str_pointb=i;
               ib=buff_numberb+1;
    ib=temp1b;
    jb=temp2b;
void Module_Initial()
RE_Module_Initial:
   if(Module_ERR==0)
      rs232_buff_cls();
      fprintf(coma,"AT\r\n");                         //check module
      delay_ms(200);
      strcpy(check_str,"OK");
      string_buff_check(2);
      if(fund_str_point==512)
         fprintf(coma,"AT Command Error...\r\n");
         GOTO RE_Module_Initial;
   setup_wdt(WDT_OFF);
   Module_ERR = 0;   GSM_Inlcnt = 0;   Msg_ERR = 0;   GPRS_ERR = 0;
   SISW_ERR = 0;
   fprintf(coma,"coma working OK ... \r\n");
   fprintf(comb,"comb working OK ... \r\n");
   output_high(EEPROM_SELECT);                  //SPI CS Initial
   delay_ms(2000);
   Module_Initial(); //<--- First do this
   for(;;)
          delay_ms(2000);
There is PIC .h file.
#include <24FJ256GB106.h>
#FUSES ICSP1                    //ICD uses PGC1/PGD1 pins
#FUSES WINDIS                   //Watch Dog Timer in non-Window mode
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
#FUSES PR                       //Primary Oscillator
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO                  //OSC2 is clock output
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES WPEND_LOW
#FUSES NOWPCFG
#FUSES NOWPDIS
#FUSES WPFP3
#FUSES WPFP4
#FUSES PLL6                   //Divide By 12(48MHz oscillator input)
#FUSES DISUVREG
#FUSES WPFP5
#FUSES WPFP6
#FUSES WPFP0
#FUSES WPFP1
#FUSES WPFP2
#FUSES WPFP7
#FUSES WPFP8
#FUSES RESERVED                 //Used to set the reserved FUSE bits
#use delay(clock=22118400)
PostPosted: Fri Feb 12, 2010 2:28 am     Reply with quote
- Interrupt nesting is disabled by default, you don't need to disable or enable any interrupts in the interrupt function.
- You're writing one byte out of bounds of your rx buffers (rs_buffb[512]).
Apart from these points, I don't see problems with your code. RS232 interrupts are generally working with PIC24 chips and recent PCD versions.
PostPosted: Fri Feb 12, 2010 4:00 am     Reply with quote
Has the problem with the UART numbers being reversed, been fixed?.
If not, then the code would hang.
I really would suggest, getting just _one_ UART working first.
PostPosted: Fri Feb 12, 2010 7:20 am     Reply with quote
Yes, if I remember right. But it's a good idea to check correct SFR usage and PIN_SELECT coding anyway. It has
been partially wrong with PIC24FJxxGB1xx in previous compiler versions and is still wrong for some more exotic
PIC24 types.
sindyme
PostPosted: Fri Feb 12, 2010 8:34 am     Reply with quote
PIC24 types.
I will continue try. This week is chinese new year , I have seven day's holiday.
Next week I will try again ~
