JamesW, Kent, England Guest
Should interrupts be disabled during master i2c activity? |
Posted: Mon Jan 18, 2010 9:22 am |
Hi folks,
A few years ago it was recommended on this forum that interrupts should be disabled when reading/writing for an I2C peripheral - so that the irq's couldn't pulse stretch the signals. (I am the bus master)
If you are using an hardware I2C SSP built into the processor - does this apply?
The reason is that I am trying to write an I2C recovery routine, that deals with what happens if a peripheral stops responding and locks the bus up. If I can use a timer interrupt, I can restart the processor after a certain time - if not - can anyone suggest an alternative method (as sometimes I2C write hangs)?
James
James |
bkamen
Posted: Mon Jan 18, 2010 12:51 pm |
No, not really.
And I2C is a clocked data stream anyway, so timing is pretty flexible.
it's RS232 (software UARTs) where timing can really muck up the works.
Now, some I2C chips *might* have timeouts. So that becomes a "try it and if it breaks look deeper".
But a hardware I2C makes interrupts even more irrelevant.
