Hi all, I'm doing SPI on a project and I'm new to spi. How do i assign the register sspcon1 and sspstat?
Is it this (at declaration):
#define sspcon1
#define sspcon2
#define sspstat
Or this (at declaration):
# byte sspcon1 = 0x20
# byte sspstat = 0x00
Or this (in main code):
sspcon1 = 0x20;
sspstat = 0x00
Or other method? I tried the first and second declarations above but my code didn't work. I tried the third declaration but compiler said "the line has no effect". What should I do? I just want to perform the most basic spi of master send data to slave using PIC16F877A for both. Pls help.
Posted: Sat Dec 19, 2009 10:46 pm
Do you have the CCS compiler ? The following links show how to
write SPI code if you have the CCS compiler:
