help needed on spi master and slave c code
egg86
PostPosted: Sat Dec 19, 2009 10:20 pm     Reply with quote
Hi all, I'm doing SPI on a project and I'm new to spi. How do i assign the register sspcon1 and sspstat?
Is it this (at declaration):
#define sspcon1
#define sspcon2
#define sspstat
Or this (at declaration):
# byte sspcon1 = 0x20
# byte sspstat = 0x00
Or this (in main code):
sspcon1 = 0x20;
sspstat = 0x00
Or other method? I tried the first and second declarations above but my code didn't work. I tried the third declaration but compiler said "the line has no effect". What should I do? I just want to perform the most basic spi of master send data to slave using PIC16F877A for both. Pls help.
PostPosted: Sat Dec 19, 2009 10:46 pm     Reply with quote
Do you have the CCS compiler ? The following links show how to
write SPI code if you have the CCS compiler:
Here is a simple test program to show some activity on the SPI master's
clock and data pins:
http://www.ccsinfo.com/forum/viewtopic.php?t=40998&start=4
Example of an SPI master program:
http://www.ccsinfo.com/forum/viewtopic.php?t=41008&start=5
Here are some sample SPI master and slave programs:
http://www.ccsinfo.com/forum/viewtopic.php?t=39145
http://www.ccsinfo.com/forum/viewtopic.php?t=26888
