All that i need is to send an analog signal to the controller based on the soil resistance. I need the hardware circuitry.
I shall take care of the programming. _________________ Regards
Karthi
SherpaDoug
Posted: Mon Dec 14, 2009 8:29 pm
I really don't like that circuit. Unless someone can explain how it works to me I would start with the basic ohmmeter circuit in the Microchip application note AN512. It is written in assembler, but if you understand it you can write it in C easily enough. _________________ The search for better is endless. Instead simply find very good and get the job done.
Posted: Tue Dec 15, 2009 9:21 am
Another problem, actually for all DC powered soil sensors, is the bias that accumulates over time due to the sensor current flow. This can be eliminated by using an AC source to the sensor, then converting the signal to dc for the PIC. Another option is to control the power to the sensor and only power it when a reading is desired.
Jay
