Help needed for soil moisture sensing...
karthi27
PostPosted: Mon Dec 14, 2009 7:51 pm     Reply with quote
I need to design a cheap soil moisture sensor using PIC 16f877.
I referred http://www.faludi.com/2006/11/02/moisture-sensor-circuit/
I simulated it in multisim. It didn't yield satisfactory results.
All that i need is to send an analog signal to the controller based on the soil resistance. I need the hardware circuitry.
I shall take care of the programming.
Regards
Karthi
SherpaDoug
PostPosted: Mon Dec 14, 2009 8:29 pm     Reply with quote
I really don't like that circuit. Unless someone can explain how it works to me I would start with the basic ohmmeter circuit in the Microchip application note AN512. It is written in assembler, but if you understand it you can write it in C easily enough.
PostPosted: Tue Dec 15, 2009 9:21 am     Reply with quote
Another problem, actually for all DC powered soil sensors, is the bias that accumulates over time due to the sensor current flow. This can be eliminated by using an AC source to the sensor, then converting the signal to dc for the PIC. Another option is to control the power to the sensor and only power it when a reading is desired.
Jay
