Sleep and Idle Modes on an 18F4685
JohnHopkins
PostPosted: Fri Dec 11, 2009 11:36 am     Reply with quote
PIC- 18F4685
Compiler- 4.085
I am trouble with the PIC low power modes.
When I put the PIC in SLEEP mode, it draws microamps.
However, when I put the PIC into IDLE mode, it draws ~ 5 mA, which is about the same as it draws in RUN mode. There appears to be no power saving in IDLE mode. I have all the tristates set to input, so it should not be driving any pins. I also used printfs to check the SFRs and confirm that all the peripherals were off. But it looks like some peripheral is on and consuming power...
I used printfs to confirm that the PIC goes into IDLE mode and never wakes up, since all interrupts are disabled.
Here's a test program:
#include <18F4685.h>
#device PASS_STRINGS = IN_RAM
#include <stdio.h>
#include <string.h>
#use delay(INTERNAL=8M, clock=16M)
#fuses INTRC, NOWDT, NOLVP, NOPBADEN, NOBROWNOUT, NOPROTECT//, DEBUG
//SFRs///////////////////////////////////////////////////////////////////////////////////////////////////
#byte OSCCON   =      0xFD3
#bit  IDLEN    =       OSCCON.7
#byte CCP1CON   =      0xFBD
#byte ECCP1CON   =      0xFBA
#byte SSPCON1   =      0xFC6
#byte RCSTA      =      0xFAB
#byte ADCON0   =      0xFC2
#byte CMCON      =      0xFB4
#byte CVRCON   =      0xFB5
#byte HLVDCON   =      0xFD2
#byte CANSTAT   =      0xF6E
//Debug
//#use rs232(BAUD=9600, XMIT=PIN_B3, BITS=8, PARITY=N)
//Main////////////////////////////////////////////////////////////////////////////////////////////////////////
void setup_clk() {
   setup_oscillator(OSC_16MHZ);
   delay_ms(10);
void setup_io() {
   //set tris
   set_tris_a(0xFF);
   set_tris_b(0xFF);
   set_tris_c(0xFF);
   set_tris_d(0xFF);
   set_tris_e(0xFF);
void go_to_sleep() {
   IDLEN=1;
   sleep();
void main(void) {
   //setup pic
   setup_clk();
   disable_interrupts(GLOBAL);
   setup_io();
   CMCON=0;
   CANSTAT=0x20;
/*   printf("Current Peripheral SFR Status\r\n");
   printf("CCP1CON      =      %X\r\n",CCP1CON);
   printf("ECCP1CON   =      %X\r\n",ECCP1CON);
   printf("SSPCON1      =      %X\r\n",SSPCON1);
   printf("RCSTA      =      %X\r\n",RCSTA);
   printf("ADCON0      =      %X\r\n",ADCON0);
   printf("CMCON      =      %X\r\n",CMCON);
   printf("CVRCON      =      %X\r\n",CVRCON);
   printf("HLVDCON      =      %X\r\n",HLVDCON);
   printf("CANSTAT      =      %X\r\n",CANSTAT);*/
   while(1) {
   //   printf("I'm asleep!\r\n");
      go_to_sleep();
   //   printf("I'm awake!\r\n");
Thanks for your help.
JohnHopkins
Shutting Down CAN
PostPosted: Fri Dec 11, 2009 12:05 pm     Reply with quote
I just realized that I was trying to disable CAN in CANSTAT, when I should have used CANCON. I made the change, but that didn't solve the problem. However, when I read CANSTAT, it tells me that it is in configuration mode, not disable mode. So it looks like CAN is still on...
#include <stdio.h>
#include <string.h>
#byte RCSTA      =      0xFAB
#byte CMCON      =      0xFB4
#byte CANCON   =      0xF6F
//Debug
void setup_clk() {
   delay_ms(10);
void setup_io() {
   //set tris
   set_tris_a(0xFF);
   set_tris_b(0xFF);
   set_tris_c(0xFF);
   set_tris_d(0xFF);
   set_tris_e(0xFF);
   IDLEN=1;
   sleep();
void main(void) {
   //setup pic
   setup_clk();
   setup_io();
   CMCON=0;
   CANCON=0x20;
   while(1) {
      go_to_sleep();
PostPosted: Fri Dec 11, 2009 1:53 pm     Reply with quote
Your program is too complicated. Also, according to the Electrical
Characteristics section of the 18F4685 data sheet, the speed of the
internal oscillator makes a huge difference in the current consumption
during idle mode. So why not try it with the lowest speed ?
Try the incredibly stripped down program shown below. I don't have
your PIC so I can't test this, but I think it would be a good test.
#fuses INTRC, NOWDT, NOLVP, NOPBADEN, NOBROWNOUT, NOPUT
setup_oscillator(OSC_IDLE_MODE | OSC_INTRC | OSC_31KHZ);
sleep();
JohnHopkins
That did the trick
PostPosted: Fri Dec 11, 2009 5:59 pm     Reply with quote
Thanks for your input. Reducing the clock speed reduced the power consumption by ~90%, so we are good.
Just as a point of interest, we still can't put the CANCON register into Disable mode. The CANSTAT register always indicates that the CAN is in Configuration mode. However, this does not draw a noticeable amount of power at lower frequencies.
