JohnHopkins Guest
Sleep and Idle Modes on an 18F4685 |
Posted: Fri Dec 11, 2009 11:36 am |
PIC- 18F4685
Compiler- 4.085
I am trouble with the PIC low power modes.
When I put the PIC in SLEEP mode, it draws microamps.
However, when I put the PIC into IDLE mode, it draws ~ 5 mA, which is about the same as it draws in RUN mode. There appears to be no power saving in IDLE mode. I have all the tristates set to input, so it should not be driving any pins. I also used printfs to check the SFRs and confirm that all the peripherals were off. But it looks like some peripheral is on and consuming power...
I used printfs to confirm that the PIC goes into IDLE mode and never wakes up, since all interrupts are disabled.
Here's a test program:
Code: | #include <18F4685.h>
#device PASS_STRINGS = IN_RAM
#include <stdio.h>
#include <string.h>
#use delay(INTERNAL=8M, clock=16M)
#fuses INTRC, NOWDT, NOLVP, NOPBADEN, NOBROWNOUT, NOPROTECT//, DEBUG
//SFRs///////////////////////////////////////////////////////////////////////////////////////////////////
#byte OSCCON = 0xFD3
#bit IDLEN = OSCCON.7
#byte CCP1CON = 0xFBD
#byte ECCP1CON = 0xFBA
#byte SSPCON1 = 0xFC6
#byte RCSTA = 0xFAB
#byte ADCON0 = 0xFC2
#byte CMCON = 0xFB4
#byte CVRCON = 0xFB5
#byte HLVDCON = 0xFD2
#byte CANSTAT = 0xF6E
//Debug
//#use rs232(BAUD=9600, XMIT=PIN_B3, BITS=8, PARITY=N)
//Main////////////////////////////////////////////////////////////////////////////////////////////////////////
void setup_clk() {
setup_oscillator(OSC_16MHZ);
delay_ms(10);
void setup_io() {
//set tris
set_tris_a(0xFF);
set_tris_b(0xFF);
set_tris_c(0xFF);
set_tris_d(0xFF);
set_tris_e(0xFF);
void go_to_sleep() {
IDLEN=1;
sleep();
void main(void) {
//setup pic
setup_clk();
disable_interrupts(GLOBAL);
setup_io();
CMCON=0;
CANSTAT=0x20;
/* printf("Current Peripheral SFR Status\r\n");
printf("CCP1CON = %X\r\n",CCP1CON);
printf("ECCP1CON = %X\r\n",ECCP1CON);
printf("SSPCON1 = %X\r\n",SSPCON1);
printf("RCSTA = %X\r\n",RCSTA);
printf("ADCON0 = %X\r\n",ADCON0);
printf("CMCON = %X\r\n",CMCON);
printf("CVRCON = %X\r\n",CVRCON);
printf("HLVDCON = %X\r\n",HLVDCON);
printf("CANSTAT = %X\r\n",CANSTAT);*/
while(1) {
// printf("I'm asleep!\r\n");
go_to_sleep();
// printf("I'm awake!\r\n");
Thanks for your help. |
JohnHopkins Guest
Shutting Down CAN |
Posted: Fri Dec 11, 2009 12:05 pm |
I just realized that I was trying to disable CAN in CANSTAT, when I should have used CANCON. I made the change, but that didn't solve the problem. However, when I read CANSTAT, it tells me that it is in configuration mode, not disable mode. So it looks like CAN is still on...
#include <stdio.h>
#include <string.h>
#byte RCSTA = 0xFAB
#byte CMCON = 0xFB4
#byte CANCON = 0xF6F
//Debug
void setup_clk() {
delay_ms(10);
void setup_io() {
//set tris
set_tris_a(0xFF);
set_tris_b(0xFF);
set_tris_c(0xFF);
set_tris_d(0xFF);
set_tris_e(0xFF);
IDLEN=1;
sleep();
void main(void) {
//setup pic
setup_clk();
setup_io();
CMCON=0;
CANCON=0x20;
while(1) {
go_to_sleep();
Posted: Fri Dec 11, 2009 1:53 pm |
Your program is too complicated. Also, according to the Electrical
Characteristics section of the 18F4685 data sheet, the speed of the
internal oscillator makes a huge difference in the current consumption
during idle mode. So why not try it with the lowest speed ?
Try the incredibly stripped down program shown below. I don't have
your PIC so I can't test this, but I think it would be a good test.
#fuses INTRC, NOWDT, NOLVP, NOPBADEN, NOBROWNOUT, NOPUT
setup_oscillator(OSC_IDLE_MODE | OSC_INTRC | OSC_31KHZ);
sleep();
JohnHopkins Guest
That did the trick |
Posted: Fri Dec 11, 2009 5:59 pm |
Thanks for your input. Reducing the clock speed reduced the power consumption by ~90%, so we are good.
Just as a point of interest, we still can't put the CANCON register into Disable mode. The CANSTAT register always indicates that the CAN is in Configuration mode. However, this does not draw a noticeable amount of power at lower frequencies. |
