SDI,SDO,SCk 3 pin mode. Is the SS pin the free to use as normal I/O?
Posted: Tue Oct 13, 2009 2:01 pm
It should be available for normal i/o.
Posted: Wed Oct 14, 2009 1:03 am
As an additional note:
The Slave Select pin is only active when the SPI hardware is used as a slave. In a master this pin is never used and free for normal I/O operations.
Don't place the SS_DISABLED define in your spi_setup call for a SPI master or it will create an invalid setup.
Torello
Posted: Thu Oct 15, 2009 11:39 am
Hi Guest,
Beware when you want to use this pin as an input!!
