If using the hw SPI is the ss pin then free?
PostPosted: Tue Oct 13, 2009 1:42 pm     Reply with quote
When using the SPI hardware module:
SDI,SDO,SCk 3 pin mode. Is the SS pin the free to use as normal I/O?
PostPosted: Tue Oct 13, 2009 2:01 pm     Reply with quote
It should be available for normal i/o.
PostPosted: Wed Oct 14, 2009 1:03 am     Reply with quote
As an additional note:
The Slave Select pin is only active when the SPI hardware is used as a slave. In a master this pin is never used and free for normal I/O operations.
Don't place the SS_DISABLED define in your spi_setup call for a SPI master or it will create an invalid setup.
Torello
PostPosted: Thu Oct 15, 2009 11:39 am     Reply with quote
Hi Guest,
Beware when you want to use this pin as an input!!
http://www.ccsinfo.com/forum/viewtopic.php?t=31562&highlight=
Edwin.
